Go for an sc14! alot of work to fit but good gains in terms of torque/response
Heres a setup i helped a mate with on a ke35 we built
http://www.toymods.org.au/forums/sho...ze+ke35&page=4
Yep - crank angle sensor - I know what that is..Surrounded by Cam gear, cam-cover, intercooler mount bracket & far left exhaust port.
So is that why it has the off-set bolt in a slot on the left side? ..so it can be rotated up & down a bit to reset base timing signal back to the ECU?
Also not sure what is meant by "shorting pins"
Pretty sure my old man's got a timing light & can show me how to use
G'day Kev' How are ya mate?
Nice write up on your mate's KE.
Definitely enjoying learning & considering about various different set ups & the s/c14 would be a great way to get more power without thrashing the hell out of a s/c12
SC14 - fitment guide:
http://www.toymods.org.au/forums/sho...=1#post1271021
Would love to see one for FWD / AWD set-up
To short the pins, you have to find the diagnostic connector in the engine bay (little black box with 'diagnostic' on the top) then open it up.
In the lid you'll see the names of all the connections inside. Find Te1 and E1 and get a paperclip or bit of wire and join those two together with the car turned off.
When you turn the key to the 'on' position without starting it, the check engine light will flash any error codes your ECU might have.
When you actually start the engine, the timing will be locked by the ECU and you can use the timing light and loosen the bolt on the crank angle sensor and rotate it to get your 12 degrees of advance.
Stop the engine, pill the wire out of the diagnostic connector and you're ready to drive.
you might be interested in a setup I did on a friends KE35. (not the same one as above). As mentioned at the top on thread we moved the thottle body so the pressure from the S/C when the throttle closes does do damage. (thats why turbos use blow off valves).
In the third picture we bolted the throttle body to the pipe coming out from under the inlet manifold. the car when it was complete was a monster to drive. SO much power revved out as well. Everyone says S/Cs cant handle revs. LIES!!! PS had 14psi boost with standard pulleys
Hi Kev'
How did those power door lock actuators work out as a replacement for the AE95's vaccuum drum actuator that locks the central diff?
http://www.toymods.org.au/forums/showthread.php?t=28002
Do you rekon they're good enough to last in muddy conditions or pass inspection by an engineer?
I went from 3sge TB in front of an SC14 to NA inlet and found a huge improvement especially from 4500 upwards revving cleanly to red line with enough of a change that the factory ecu timing and fuelling would cause pinging through the mid range.
I wouldn’t recommend the TB after the SC because you need to run a large bypass valve for when throttle closes and it also make it quite loud and anti social so stick to TB before.
Vic.
So am I hearing you right?
You kept the throttle body in the same position but upgraded it to a 3SGE?
Sounds good.. ..& I agree, I'm not a huge fan of the "WHAAPISSHHH!!!!" sound made by waste gates.
Your results sound good.
So it's 3SGE TB, SC14, IC, NAintake.. Have you got any pics?
Was it transverse mount or north south?
Celicas have the engines you want. Maybe other cars but I'm not sure. You also want the rubber adapter that sits on the throttle body too, until you make up a proper aluminium adapter.
Like this:
What year celicas?
I take it, this is 1st gen:
Make/Model: Toyota Celica, RA65 11/84-11/85
Engine: 2.0
Transmission: AUTO
Year: 1984
Odometer: 465521
Date In Stock: 16 Dec 2010
& this is the 2nd OR 3rd generation that I'm looking for:
Make/Model: Toyota Celica, ST162L 10/86-03/89
Engine: 2.0
Transmission: 5SPD
Year: 1987
Odometer: 307661
Date In Stock: 14 Dec 2010
Or am I sh*t outta luck? ..That's all they have in stock at the mo'
BTW sexeh fab work on the adapter
Last edited by PrettyCoolWagon; 07-01-2011 at 11:37 PM. Reason: To provide celica details
