Page 1 of 5 123 ... LastLast
Results 1 to 15 of 67
Thread: do automatics need to run a bov?
    Junior Member Grease Monkey JZA20's Avatar
    Default do automatics need to run a bov?
    Hi people, im going the single route on my auto 1j mz20 and i was told by a 'friend' that autos dont need to run blow off valve and that it robs it of power, is this correct? I was a bit sceptical...
    cheers josh
    Default Re: do automatics need to run a bov?
    Punch your "friend" in the nipple..
    BOV's arent needed on any setup.
    Junior Member Grease Monkey codez's Avatar
    Aug 2009
    BOV's arent needed.
    Isn't that what his 'friend' said?
    working hard Backyard Mechanic
    Whilst accellerating they wouldn't but when coming off boost ull need one or ull dose/flutter unless your running plumb back
    May 2007
    Quote Originally Posted by reece12 View Post
    and how does that make any difference to the automatic transmission?
    it doesn't, but unless he wants a full-sik auto, a plumb-back isn't a bad idea. Just a random Bosch one will be fine (used on turbo porsche's, etc)
    Yes, they need a BOV or you'll get flutter. Trini was an auto and she needed a BOV.
    She is now becoming a manual and is still using a BOV.
    seeyuzz
    river
    May 2007
    seeyuzz
    river
    you will get flutter regardless to if it has an auto or a manual behind it...
    or am i missing some point or joke here?
    my brothers Mitsubishi legnum is auto and has an BOV that vents to the atmosphere, it has not robbed him of any power, though it hasn't given him any extra power either.
    My dads truck has a BOV and the hamburgular has robbed him of all of this power.
    ok.
    A proper BOV will not add/reduce power.
    It may improve boost response on gear shift (point of contention), but main purpose is to shut the dose up.
    Auto, manual, makes no difference.
    Your auto will still hold more boost between shifts than any manual
    Tasmania
    i took the bov off my chaser (which is auto) and in this instace it changed my responce slightly cause they are a backwards bov. (computer holds them open untill it wants teh powaz)
    but the point here is you are driving normally (auto) then your never off the throttle severly enough to get dose (or bov release of you have one).
    1973 TA22
    Jul 2007
    the dose is your compressor stalling due to the boosted charge coming back through your compressor wheel
    bovs arent installed from factory for nothing..........
    and whether the car is auto or not doesnt matter. you still need to come off the throttle at some point
    Quote Originally Posted by midnight_purple_GA70 View Post
    Trdee explained it better , you gotta take your foot of the accellerator sometime. Haven't you seen those fully sik vl commos with automatics and no bovs.
    bollocks
    There's no 'stalling'. All a BOV does is reduce noise, end of story! They are there factory for this reason only. The performance difference from having or not is two parts of fark all (in favour of not and tested).
    So, not needed but a plumb back will most likely have you more under the radar if that's what you want.
  1. Replies: 18
    Last Post: 12-07-2009, 05:14 AM
  2. BOV not working - 1G-GTE
    By Z2TT in forum Tech and Conversions
    Last Post: 14-04-2008, 03:37 AM
  3. 7mgte - Larger BOV with highflow turbo?
    By Kedderz in forum Tech and Conversions
    Last Post: 31-01-2008, 12:38 PM
  4. tial BOV not operating correctly
    By EVOSTi in forum Tech and Conversions
    Last Post: 06-09-2006, 06:50 PM
  5. BOV question (noob alert)
    Last Post: 31-08-2006, 06:25 PM
