What he said. If you can post anywhere in the forum you're "approved" Sure youre doing it in the right place?Originally Posted by CrUZida
Are you sure you are doing it in the PARTS WANTED section?Originally Posted by chefy83
i wasnt![]()
Haha, all good now though I see. Good luck![]()
thanks man ill starta converiosn thread when i get the car tomorrow
Mz10 Ftw!
Z20's where it's at. You might have 1UZ powah, but yeah.
(rest assured... if the one-gee goes POP, then i may consider a UZ to replace it.. damned if ill go auto though!)
sif you want a Z20....
you know your 1G would actually be relaitevely quick... in a Z10 ofcourse![]()
MZ-10/GZ-10 hybrid turbo rolling shell, RB30 powered
IS200 - 1GFE
Must you Z10 owners rub in the weight differential all the time?!
My 1G is quick enough anyway (didnt want an ultra fast car, just another soarer!)
... will be nicer with a KKR330!![]()
Dry weight = <1200kg![]()
Yeah... well... Ive got velour and all electric options, a more modern interior and electric seats... and.... and....
ahh crap.
Damn you.
Well i might have and engine..... but it has 'Slight rod knock'![]()
Was that the short motor on ebay? Youre gonna need a head and a bottom end rebuild if so...
And if it's not, here's the link
http://cgi.ebay.com.au/TOYOTA-7MGTE-...QQcmdZViewItem
no its not... its a different complete motor
1x 7M-GTE Engine, ARP studs, HKS Metal Gasket. no turbo,
1x w58 5 Speed Manual Box
only known problems are:-
Oil leak (not sure where its coming from, but will know once it is out
very slight rod knock, so big end bearing needs replacing soon.
Wat should i pay....
Full loom and ecu? (ignitor, afm)
Flywheel/bellhousing/clutch?
