Results 16 to 30 of 65
Thread: Engine Swap for mz10
    Junior Member Grease Monkey chefy83's Avatar
    Default Re: Engine Swap for mz10
    yeah but there seem to be alot of good cheap parts for 7m;s kicking around...... budget for whole conversion is about 3-4k
    *cough* V8 *cough*
    They make a whole lot of noise but dont go any faster than a 17psi 1G
    Time slips say different.
    Hide Yo Kids Hide Yo Wife Carport Converter hamgatan's Avatar
    Quote Originally Posted by JustCallMeFrank
    ahh but they dont blow headgaskets either
    JZZ20 1988 Soarer GT Twin Turbo
    1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
    No, i'm pretty sure the heavier 1G powered car had the higher MPH at the top of the track. The fact that I launch like a girl is irrelevant.
    hehe girl *poke*
    Back in your box. Side note, going to make the trip down?
    how much harder are they to fit but
    How hard is what to fit? Given your M-series car, the 7M is the easiest swap. If you find a 1G front sump and GA61/GZ10 mounts the 1G will be the next easiest and the JZ and UZ will both be the hardest, mainly from the complications or $ involved in having manual versions.
    As this is my first real conversion im thinking keep it simple put a 7m in..... who wants to help?
    Drift barge master Backyard Mechanic orestes's Avatar
    Queensland.
    get some bonyville (SP?) engine mounts (about $300 worth) and a 1 or 2J, i'm in the process (when I can get the cash together) of putting in an atmo 2J into my GZ10... cheap enough to pick up an atmo 2J out of someones barge it's to heavy for (JZA80 or JZZ31 owners ), and makes a decent amount of power in a relatively light car like the early soarer is. Really depends though....
    a 7M will be relatively cheap, but then you'll blow a head gasket, and you'll be back to stage 1 with a $1000 hole in your pocket. ontop of that, if you're gonna swap out you may as well put something more modern in
    MZ-10/GZ-10 hybrid turbo rolling shell, RB30 powered
    IS200 - 1GFE
    ill be replacing the gasket with a better one and some arp bolts
    so it can take about 20psi ;-) so its not a prob
    I think the best way to do it will be to build up and boost the engine while its outa the car so i can keep driving it then when its ready drop it in and crank some really power right off the first key turn
    CROSSPLANE CRANK! Domestic Engineer Merudo's Avatar
    Just go for an N/A 7M. You'll still have more power than the good old M-TEU
  1. Toyota R Engine History
  2. MA70 --> JZA70 Conversion
