Results 46 to 60 of 65
Thread: Engine Swap for mz10
  1. #46
    Default Re: Engine Swap for mz10
    Quote Originally Posted by chefy83
    Nup it doesnt let me... i guess im not approved ;( anyone want to post for me???
    Are you sure you are doing it in the PARTS WANTED section?
  2. #47
    What he said. If you can post anywhere in the forum you're "approved" Sure youre doing it in the right place?
  3. #48
    Junior Member Grease Monkey chefy83's Avatar
    i wasnt
  4. #49
    Haha, all good now though I see. Good luck
  5. #50
    thanks man ill starta converiosn thread when i get the car tomorrow
  6. #51
    Mz10 Ftw!
  7. #52
    CROSSPLANE CRANK! Domestic Engineer Merudo's Avatar
    Z20's where it's at. You might have 1UZ powah, but yeah.
    (rest assured... if the one-gee goes POP, then i may consider a UZ to replace it.. damned if ill go auto though!)
  8. #53
    Drift barge master Backyard Mechanic orestes's Avatar
    Queensland.
    sif you want a Z20....
    you know your 1G would actually be relaitevely quick... in a Z10 ofcourse
    MZ-10/GZ-10 hybrid turbo rolling shell, RB30 powered
    IS200 - 1GFE
  9. #54
    Must you Z10 owners rub in the weight differential all the time?!
    My 1G is quick enough anyway (didnt want an ultra fast car, just another soarer!)
    ... will be nicer with a KKR330!
  10. #55
    Dry weight = <1200kg
  11. #56
    Yeah... well... Ive got velour and all electric options, a more modern interior and electric seats... and.... and....
    ahh crap.
    Damn you.
  12. #57
    Well i might have and engine..... but it has 'Slight rod knock'
  13. #58
    Was that the short motor on ebay? Youre gonna need a head and a bottom end rebuild if so...
    And if it's not, here's the link
    http://cgi.ebay.com.au/TOYOTA-7MGTE-...QQcmdZViewItem
  14. #59
    no its not... its a different complete motor
    1x 7M-GTE Engine, ARP studs, HKS Metal Gasket. no turbo,
    1x w58 5 Speed Manual Box
    only known problems are:-
    Oil leak (not sure where its coming from, but will know once it is out
    very slight rod knock, so big end bearing needs replacing soon.
    Wat should i pay....
  15. #60
    Full loom and ecu? (ignitor, afm)
    Flywheel/bellhousing/clutch?
  1. Toyota R Engine History
  2. MA70 --> JZA70 Conversion
