Results 16 to 24 of 24
Thread: Welding a MA61 LSD Diff up
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    Default Re: Welding a MA61 LSD Diff up
    thanks for pointing out my mistake wilbo
    i read the ma70 bit wrong.
    you can shim it sooo tight that it virtually becomes a locker, because the plates are jammed together.
    You want to shim it if possible, because i've always thought that the shafts get a little less of a hard time if you don't run a locker. A working properly working lsd should lock up the diff every time you want.
    Lockers are only good for 4wds, and 4wds suck
    /me runs
    DAN
    The old One Backyard Mechanic
    Buttocks
    Don't weld the LSD in the car. Sell the hemisphere to me for $200 plus postage. Go to the wrecker and buy an F series diff spider gear for $30. Have it welded for $30. Profit $140. We will all then be real happy.
    Craig
    Jun 2006
    I couple of my friends and myself are going to Re-shim it
    Good I am now Happy
    what? Automotive Encyclopaedia EVOSTi's Avatar
    best way mate
    Junior Member Backyard Mechanic 1jzracing's Avatar
    i have always used lockers, tried running LSD's... they are great for the first few times out on the track then they go off and just dont hook up without another rebuild
    likes of a torsen might be ok
    contrary to common belief a locker will drastically REDUCE oversteer and give you so much bite off a corner its quite glorious
    the best way to make a locker is to get it cast with alloy NOT welded ... indestructable!!!
    i used to have a sidline casting centres for people if anybody wants one done let me know
    cost a couple hundred bucks but have never in 15 years seen one fail!
    ps can cast LSD's too but better to start with an open centre
    lol but you would use what on the street?
    Quote Originally Posted by 1jzracing
    i found when i had the locker in the 23, it would tend to push understeer alot more then try and push oversteer....
    but that was until one 1/2 of the sper gears decide to punch out the rear casing
    blake
    i find the rolla has alot more drive out of corners, tends to understeer less imo.
  1. changing the gear ratio's in hilux diff.
  2. Diff housing welding
    Last Post: 23-06-2006, 11:18 PM
  3. ma61 diff in a ta22?
    By weapon x in forum Tech and Conversions
    Last Post: 19-04-2006, 11:25 PM
  4. What is the best oil to use in a stock MA61 diff?
    Last Post: 12-01-2006, 09:12 PM
