Results 1 to 15 of 24
Thread: Welding a MA61 LSD Diff up
    Jun 2006
    Default Welding a MA61 LSD Diff up
    I have a MA61 with a 1JZ installed, at the moment the car slides going right and open wheels going left which is terrible. My plan was to weld the spider gears together (not me someone who knows what there doing) problem is everyone i've talk to hasn't done it and the people who have don't want to do it (illegal Pfft) Can it be done with the diff centre still inside the diff or does it have to be taken out to be welded up
    I'm in the Sunshine Coast QLD if anyone knows how to and more importantly whats to make a quid
    Default Re: Welding a MA61 LSD Diff up
    It depends.
    Firstly you SHOULD have an lsd already if the diff hasn't been changed from factory. You won't be able to weld the center in that (the LSD) easily. In that case I suggest that you either get a new LSD (torsen ) or get your LSD reshimmed (or buy and open center diff to weld up).
    Secondly if it turns out that you do have an open diff, (or you decide to go and buy and open diff to weld up) there should be buckets load of room to get the old 'CIG' in there to make the locker....
    I'd suggest the LSD option myself
    Jun 2006
    It 100percent has a LSD in it. How much does a replacement centre cost (roughly)
    Basically i'm asking what kind of costs are involved if i go re-shimming or replacement
    what? Automotive Encyclopaedia EVOSTi's Avatar
    definately LSD if you have the cash. but if you do weld, you can weld it still in the car. dont just weld the side gears to the pinion gears, weld the gears t othe housing aswell. i had the side gears welded to the pinion gears and the pinion gears shit themselves.
    above is right!
    Buttocks i take it you have never driven a welded diff car? there not the best in the wet.
    there is a good reason they are illegal.
    just get an lsd and you will be happy, i havnt used a locker on the track for many many years as a good lsd leaves a locker for dead.
    Jun 2006
    I have driven a few locked diff cars before so i'm not to worried about drivability, more about Cost
    lockers are GREAT in the wet what are you talking about?
    yep they sure are and till you kill someone else when you turn it around in the wet
    Quote
    "I have driven a few locked diff cars before so i'm not to worried about drivability, more about Cost"
    gee that suprises me.
    Jun 2006
    I'm not a young kid thats been driving for 3 years
    Give me options people what kind of other diffs fit straight in MA70 etc?
    Jun 2006
    Whats involved in re-shimming these diffs??
    a locked diff will make it more likely to step out in the wet but id say its a bit more predictable and more controlable.
    re-shimming an LSD involves taking the diff to a diff specialist. it can be done at home but im guessing if you need to ask you probably cant do it anyway. thats not an attack on you or anything, they are just a bit of mucking around.
    Jun 2006
    I do most of my own shit, just never had to do a diff before. If its a similar diff design to a S13 R200 Diff it won't be a problem
    http://d1nz.org.nz/forum/viewtopic.php?t=9610
    Asking questions is the first step to learning, hence all my recent posts
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    http://www.cygnusx1.net/supra/librar...ra/RA_037.html edit
    Thats the toyota supra workshop manual, pull it down, measure it all up, buy fatter shims, put it back together, do skids
    Some careful measurement and guesswork should give you a tighter than factory spec lsd.
    Dan
    If it is and lsd it will look like the above link...
    I can't see anyway on earth that you can weld that with it in the diff casing!
    Jun 2006
    hmmmmm, now to shim or to weld that is the question
  1. changing the gear ratio's in hilux diff.
  2. Diff housing welding
    Last Post: 23-06-2006, 11:18 PM
  3. ma61 diff in a ta22?
    By weapon x in forum Tech and Conversions
    Last Post: 19-04-2006, 11:25 PM
  4. What is the best oil to use in a stock MA61 diff?
    Last Post: 12-01-2006, 09:12 PM
