Results 1 to 3 of 3
Thread: 1uz bellhousing dimensions..
    Penrith BC
    Default 1uz bellhousing dimensions..
    for those folks with custom 1uz manual bellhousings, whats the depth? ie dellow, crs, qca (?) and others?
    ive just spoken to damien (1uzquadcam) in NZ, theirs is 164mm with the clutch yoke located on the RHS of the bellhousing.
    just wondering if there was much variance in those available?
    also - does anyone know the depth of the standard auto bellhousing for comparison?
    ed
    ../delete/ban
    tech moderator
    Junior Member Backyard Mechanic Dimitri's Avatar
    Default Re: 1uz bellhousing dimensions..
    given the same input shaft/same box, wouldnt the depth be fairly similar? as long as spigot bearing position was the same? is there provision for the spigot in the 1uz crank? or do you run the spigot in the flywheel in 1uz manual setups?
    May as well post these here too for folks that are looking.
  1. A-series bellhousing to OLD T-series transmission
    By Toycrash in forum Engine & Driveline Conversions
    Last Post: 21-06-2008, 04:24 PM
  2. 1UZ Manual
    By mullett in forum Tech and Conversions
    Last Post: 02-06-2007, 01:31 PM
  3. 1uz Ms65. I Need Some Advise
    By AZZTOY in forum Tech and Conversions
    Last Post: 19-03-2006, 03:43 PM
  4. 1UZ into RA65 - Drift car.
    By nihilism in forum Tech and Conversions
    Last Post: 08-02-2006, 10:16 AM
