Page 1 of 4 123 ... LastLast
Results 1 to 15 of 47
Thread: 1UZ Manual
    Default 1UZ Manual
    The latest update on the RA60 rallycar saga: we've conveniently got a 1UZ just lying around, and in absence of anyone wanting to buy it, and for the 'why the hell not' factor, it's being sized up for the RA60. Next problem is a manual box. I take it there aren't any that will bolt up, but we do have a W58. CRT do a bellhousing...is it any good? Also, what clutch, flywheel, pressureplate combos does everyone run for these? Googled a bit, and searched the old site, but didn't seem to be much info out there...
    RM.
    Default Re: 1UZ Manual
    Search, and ye shall find.
    Info is EVERYWHERE
    http://toymods.net/forums/showthread.php?t=3247
    tasmania
    i think to flywheel is a custom job, so you get it made to fit a suitable pressure plate(large!).
    I thought you figured out a stock Toyota flywheel that fit perfectly?
    Quote Originally Posted by mullett
    Its CRS.
    CRS make a kit which will have bellhousing, flywheel, clutch, clutch slave, etc, etc for mating a W58 to the 1UZ.
    Apparently a 3SGE/3SGTE flywheel fits, but the teeth on the ring-gear are backwards, so some mods have to be done to fix that before it can be used.
    There is a kit in construction through that will mate the r154 to the 1UZ. This will retain the factory clutch , pressure plate and thrust bearing. The advantages of being able to get a clutch plate , slave cylinder anywhere to suit the pull type clutch and all the heavy duty clutches available to suit your desired power levels. So its a custom flywheel and bellhousing basically. Neil at Rush Imports is funding the prototype and will sell them after he fits the first one to his Soarer. Price hasn't been released yet, but he is due to get the first one in the next couple of weeks.
    Quote Originally Posted by acmtt
    By CRS?
    I thought CRS already had a kit to do this?
    No, Neil of Rush Imports is doing a kit, getting his own bellhousings made.
    As for the 3SGTE flywheel
    IT DOESN'T BOLT ON AND SHOULD NOT BE USED
    The bolts holes are INCORRECT and require redrilling if you are that was inclinded.
    Redrilling flywheels is bad mmkay.
    (last comment wasn't pointed at you MWP, but people who think its ok to do so)
    last comment wasn't pointed at you MWP, but people who think its ok to do so[/SIZE]
    No problem.
    I didnt know they had to be redrilled... i just saw it mentioned else where that they fit.
    Yeah, everywhere you read says IT FITS IT FITS.
    And then you see some pictures of people who have used one, and its been redrilled.
    A typical USA-born incorrect fact.
    Junior Member Backyard Mechanic manny's Avatar
    The mammoth 2UZ flywheel obviously fits, but isn't there a US manual Camry engine with a flywheel that bolts on with no mods? I vaguely remember reading about it some time ago.
    GSE20 IS250 - daily
    Twisted ****** Backyard Mechanic .T.'s Avatar
    i have alloy flywheels for them by the way
    had adaptor plates ofr supra gearboxes as well, but someone stole the test adaptor i had
    T
    New Zealand
    There is a place in NZ that makes a plate that allows a W series box to bolt to the auto bellhousing, will try to find more details. Think they make the flywheels too.
    Callum
    Callum.
    All that is answered in the link I provided above.
  1. 1uz Ms65. I Need Some Advise
    By AZZTOY in forum Tech and Conversions
    Last Post: 19-03-2006, 03:43 PM
  2. 1UZ into RA65 - Drift car.
    By nihilism in forum Tech and Conversions
    Last Post: 08-02-2006, 10:16 AM
