And Stewart told me some of you have had leaking problems with this conversion?
I'm not sure what might caused this, but it might have been because the small bearing trannys counter shafts front bearings circlip is bigger on outter diameter than the big bearing ones.
And it wont go into the groove it's supposed, so the bellhousing wont go against transmissions sealing surface and it will be leaking.
Big bearing circlip will do the trick.
I have to still measure the clearance for countershafts bolt to bellhousing.
