see my recent article on the topic
https://www.lextreme.com/scan-tools-...-engine-swaps/
				 Need help with wiring in an OBD plug for the 1JZ/2JZ VVTI JZX110/JZS171/JZS161
				Does anyone know how to wire an OBD plug with the 1jz VVTI jzx110/jzs171 ECU? Same as the Aristo 2JZ VVTI.
I've done a conversion into another car using the stock jzs171 ecu, I can see the SIL pin on wilbos 2JZ VVTI wiring page is used to output OBDII information from the ECU but I'm not sure how I would wire in a connector.
I've found this link: [http://www.2jzgarage.com/2013/01/2jz...Kc1KQZVIfc_pk) which tells me how I can view the OBD information on my phone using a bluetooth scanner but I need a pinout or something to wire in the plug if anyone can help.
 Re: Need help with wiring in an OBD plug for the 1JZ/2JZ VVTI JZX110/JZS171/JZS161
				Awesome, thanks for that. Just a couple of questions: on the diagram it runs 12v off the battery, this won't drain it will it? And I'm guessing TC pin goes to #5 signal ground?
				Looks like TC just goes to pin 13, so I guess pin 5 is just another chassis ground?
				TC goes to pin 13 SIL goes to pin 7 Earth is pin4 12v to pin16. I use a Launch Creader VI+ to read codes and an ELM327 [I use HH OBD ADVANCED unit ]with my smartphone running inCarDoc Pro to see live feed. Pay the few dollars for the Pro version.
Jealousy is a curse
