Results 1 to 15 of 22
Thread: 2jz-gte vvti jzs161 Mx83 cressida wiring help needed
    Aug 2013
    Texas
    Default 2jz-gte vvti jzs161 Mx83 cressida wiring help needed
    So... I've used
    http://wilbo666.pbworks.com/w/page/4...ngine%20Wiring
    and
    http://members.shaw.ca/boltz/7MGTE-M...ness_Plugs.htm
    to rewire the MX83 T5 22 pin ECu connector into F60 and F59 of the Jzs161 connectors
    I tried comparing the engine to body loom connectors, on wilbo666's page, but they don't look similar.
    Can anyone help me with these connectors?
    more more more
    http://home.exetel.com.au/madmont/mx83engine.jpg
    Aug 2013
    Texas
    Default Re: 2jz-gte vvti jzs161 Mx83 cressida wiring help needed
    seeking advice / guidance =\
    Aug 2013
    Texas
    other project
    Nov 2011
    the top few pics are all for the auto transmisson
    one of the pics might be igniter plug
    and the other pic might be the air flow meter
    did uget the air flow meter and the ignite
    or did u buy it cheap of ebay with all the good stuff missing
    Nov 2011
    not igniter
    tops pics are for auto trans
    next few pics are air flow meter
    4 pin plug is for oxygen sensor probably
    Aug 2013
    Texas
    Yes, I have the igniter and it is plugged into a connector.
    air flow meter I would have to check
    Aug 2013
    Texas
    Nope no air flow meter
    Junior Member Grease Monkey chaserbuddy's Avatar
    Feb 2008
    1st one is most likely to fusebox enginebay (black)
    2nd is od clutch for trans or spd sensor (2pin black)
    3rd is tranmission gear selector (light grey)
    4th is the solenoid plug trans (4 pin grey)
    5th should be afm (5pin black)
    Feb 2008
    sorry 4th O2 sensor plug just realised its with the afm plug
    Nov 2011
    nope not engine bay plug
    the last one or two are air flow meter for sure
    the 4 pin one should be o2
    and all the rest are for transmission inhibitor, solenoids, front and back speed sensors
    u will need to source an air flow meter and u should also try get the pipe/housing it comes in as if u just get the
    bare air flow meter and then fit it to a metal pipe then some guys have had issues as these sensors are very sensitive to the air flow around them
    and have been tuned to suit the factory pipe
    Aug 2013
    Texas
    Alrighty ill work on getting those.
    What do I need to do if I'm using the stock mx83 / cressida fuse box?
    Aslong as I'm connected to the alternator, starter, and block it should be fine, right?
    Nov 2011
    not hard to do
    some people say there 7 wires only to hook up
    but I've done afew and takes about two days
    just probe all the wires and connect one at a time
    Aug 2013
    Texas
    Are you referring to probing the fuse box? It is cut and completely separated.
    - can you explain
    Are you sure jzs161 / aristos have a Air flow meter and not just a mass air flow sensor?
    - or are we assuming they are the same
    shoot me
    tape is temporary just to prevent shorts until I'm 100% its right, everything else is soldered and heat shrunk.
    Nov 2011
    that will never be 100% right
    makes my bloody eyes hurt looking at it and my 5 yr old can do better heheheh
    what are all the black wires on the ecu are u trying to lengthen the loom or did u do something stupid and buy a cut loom
    ive done afew 2j 161 and they run an air flow and make sure u put an air cleaner on the intake as last one I did was in a
    late model soarer and with thermos on it caused turbulence with the air going into air flow meter
    anyway sorry but yr on your own as this looks like a very big headfk and I know what a headfk can be
    Aug 2013
    Texas
    Yes, it will probably run lean or rich if you do not use the stock aristo MAF and air box / filter.
    -JDM jzs161 aristos use MAF not AFM
    Aristo jzs161 has the fuse box and ecu in the engine bay... Thus the ecu wires need to be extended into the cab.
    Send your 5 year old over, maybe he can help
  1. JZS155 Crown 2JZGE VVTi Wiring Diagram needed - HELP
    Last Post: 30-04-2013, 06:28 AM
  2. Tach on 1jz VVTI Cressida MX83
    By Benzini82 in forum Tech and Conversions
    Last Post: 24-11-2009, 10:57 AM
  3. mx83 cressida - vvti 1j swap
    By KAMAKAZ in forum Tech and Conversions
    Last Post: 29-06-2009, 02:26 PM
  4. Replies: 6
    Last Post: 08-01-2009, 11:57 AM
