Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 133
Thread: 5VEU Hemi
  1. #46
    Jun 2006
    Tasmania
    Default Re: 5VEU Hemi
    Quote Originally Posted by oldeskewltoy View Post
    not sure what you mean by print for them.... if you look a few posts up, you can see the invoice with the part numbers.
    I don't know how to post pics on here but I can tell you how I got around a couple of problems.
    For the dizzy I got a Chevy HEI and cut about 60mm of the shaft.
    Machined a flat to drive it same as stock and fitted the Toyo drive gear on the shaft.
    Sleeved it up to fit the block and now have a fairly foolproof ignition setup.
    As I did not have an original computer and a fair bit of the injection setup, I discarded the complete inlet manifold
    and made my own.
    It has about a 4litre plenum with 8 separate runners and run direct to each inlet port.
    On top are 2 large throttle bodies with gas[lpg]] carbies attached.
    It is in a 31 Ford and runs the stock Aisin 4 speed with overdrive.
    Not finished yet but not too soon.
    Maybe this will work
    Tassie Dave
  2. #47
    May 2019
    south Carolina
    Quote Originally Posted by rx4ord View Post
    and made my own.
    Tassie Dave
    Awesome build man. If you have pictures I would love to see how you shielded the valley and made passageways to direct the coolant.
    Sent from my SM-G935V using Tapatalk
  3. #48
    Jun 2006
    Tasmania
    If you look at the heads on page 2 you will see that they have water in and out at each end of the head.
    My manifold/valley setup blocks the front water return and I used the back 2 to return water to the radiator.I have a pipe running under
    and between the inlet runners to the front.
    You can see it here.
    Tassie Dave
  4. #49
    Aug 2012
    [QUOTE=oldeskewltoy;1623440]My 5V-EU arrives.....
    Would you know how heavy that waterpump housing and dizzie assembly and crank pulley is?
    Some of the Poms and other rover v8 racers get rid of the waterpump housing and run billet electric water pumps
    its saves about 35-40lbs and in the toyota 5v since its internally balanced and v8 engines are smooth there is no need
    for harmonic balancers for if Im not mistaken that crank pulley is just for accessories than balance.
    Without the waterpump housing, lighter crank pulleys, paradise racing roller rockers (t series head based design?), billet
    rocker towers (again paradise racing) suzuki/geo metro alternator and small 350 holley you could hit 320kgs fully dressed.
    You can go nuts for sure but what a beautiful gem of a v8 they are!!! also 90mm sleeves will raise compression nicely
    specially if you can get lighter pistons and maybe use early 1uz or similar toyota L4 rods?
    Supercharging would be the cheapest bet fed by sidedraft weber and plenty of ignition only options.
  5. #50
    Jun 2006
    Tasmania
    You have some decent ideas there. I have no idea what all that stuff weighs and don't want to find out.
    The motor has about 10,000ks and I hope not to replace any bits in my lifetime.
    I reckon with a good exhaust and the higher octane rating of gas she will get along pretty good.
    I'm running a Hilux diff and the 4speed with overdrive auto so it will get along really well
    and have some good acceleration.
    Tassie Dave
  6. #51
    oregon
    Nice hotrod!!! imaginative intake, and ignition... but I want to keep it as low as I can... my plan isn't to fit it in a hotrod.
    liteace - As to the rocker type/design, they are not the same as the "T" engine type.
    I has been a while....... the engine has finally been torn down to the last nut and bolt. The good news is all the bearings show little or no sign of wear (YEAH!), the oil pump, and housing also show no sign of wear(YEAH!), and the final bit of good news is the timing chain, and tensioners show only minimal wear (YEAH!)
    The "bad news".... the rubber "O" ring that seals each cylinder into the block will need some kind of replacement, and the bigger bad news is there is wear in the pushrod end of the rocker arms(most of them) a solution is now undecided..... and still to be determined... the lifters also show some cupping (wear). The cam and lifters are going out to Oregon Cam to get "read", so that we learn the duration, lift, and since it is a single cam - lobe separation angle....
    The block has some nifty features... the main caps are all doweled, and all the mains use studs. Additionally the oil galley plug acts as a timing chain squirter/oiler.
    the crank, and main caps
    more to come......
  7. #52
    Jun 2006
    Tasmania
    Great job. That shows me what mine is like and what about that lovely crank.
    Look forward to your next installment.
    Tassie Dave
  8. #53
    Aug 2012
    thats a solid looking engine block! pity T series aftermkt stuff doesnt work its cheap these days
    Its like a smaller keith black version of the hemi.
  9. #54
    oregon
    OST-059, and OST-060
  10. #55
    oregon
    I can't be sure.... but there are not many hemi owners who can carry both heads at the same time....*
    A bit of discovery....
    and a bit more discovery
    btw, that is one of the new Cometic head gaskets.
    More to come.....
  11. #56
    Sep 2007
    Georgia
    Question, So how did these gaskets measure or compare to the old head gaskets as far a as measurements.
    If I'm correct, your sent them sample gaskets to be remade, correct?
  12. #57
    oregon
    Quote Originally Posted by 73GTV View Post
    dimensionally they are the same... except thickness. the headgaskets are about .008" thinner now.
  13. #58
    oregon
    and a bit more discovery...... I did a bit of casting.......
    Exhaust....
    Intake....
    Both....
    more to come.....
  14. #59
    Jun 2006
    Tasmania
    Thanks for the pics.Nice ports with a top design for max acceleration of mixture.
    Are the pistons flat top??
    Best design for flame path if so.
    How much were the gaskets?
    Tassie Dave
  15. #60
    oregon
    Tassie Dave
    current piston is flat topped... has a 13cc "dome"
    Chamber volume is 68cc
    Stock (OEM) gasket is 1.5mm thick, new gasket is 1.1mm
    Target piston dome volume will be 23cc
    Gaskets were a bit over $200
  1. Toyota Hemi V8 info 5V-EU
    By Joshra23 in forum Tech and Conversions
    Last Post: 21-01-2015, 12:10 AM
  2. Whats better? 2tg hemi or peanut heads
    By mino in forum Tech and Conversions
    Last Post: 22-11-2010, 06:22 AM
  3. 2010 diff centre hemi
    By mick08 in forum Tech and Conversions
    Last Post: 06-11-2010, 06:35 PM
