Page 1 of 9 123 ... LastLast
Results 1 to 15 of 133
Thread: 5VEU Hemi
    May 2019
    south Carolina
    Default 5VEU Hemi
    Hey everyone I found an old forum from a while back about someone who had drawings for the head gaskets for these engines, but that was about as far as it went if any one has any info or experience with these engines I could really use your expertise
    Thanks.
    Sent from my SM-G935V using Tapatalk
    May 2019
    south Carolina
    Default Re: 5VEU Hemi
    Here's some pictures of her.
    Sep 2007
    Georgia
    Which chassis did it come out of?
    https://toyota.epc-data.com/crown/
    Contact this seller on Ebay, If anyone has any information, he will. Too bad you were not in Southern California on the 1st of June, the all toyota car show is there and all of the vendors would be there with all the leads and possible OEM parts required to rebuild that engine...
    https://www.ebay.com/itm/Two-Toyota-...4AAOSwYnhciheL
    May 2019
    south Carolina
    1994 toyota century I imported it from japan.
    Sep 2007
    Georgia
    No he would not have that info, it was too new... VG40, VG45 model is what i looked up on Yahoo Japan and since it was such a special car, and only specific dealerships in japan could order these vehicles, your only hope is someone back in Japan..Sorry I couldn't help you on this one...
    Maybe special order it from Cometic if you send in one of the old gaskets to have them prototype it for you as a one off special order...
    oregon
    WOW.... another 5V-EU owner...
    I too have recently purchased a 5V-EU from Yahoo Japan... mine is still in transit
    Here is the engine (from YJ auction)
    I've been scouring the internet, and other places looking for information and parts - some parts are available because they were used on other engines that are still available.
    I also tried to contact all the people referred to in the published pages from a USA Hemi book..... unfortunately those who got back in touch, no longer have any parts for them.
    I did manage to score a starter....
    ... and a factory engine manual.... my new Samsung phone does the translating
    I call my 5V-EU: Project Lit'lphant - Here is my photo album: http://ost.ebeans.ch/thumbnails.php?album=58
    As far as head gaskets... I'll likely be going to Cometic and have them custom made.
    I see you have pulled the intake from yours, are the intake gaskets re-usable? I'm kind of hoping they are similar to 4AG intake gaskets that are metal, and so could be reused..... the older 4V engine (in the photo below) doesn't use metal.....
    although it does look simple enough to make.....
    Anyway... my interest in this engine is partially fueled (like the pun?) by the engines reported mass - 130 kilos!
    Other details I've gleaned from the internet....
    Engine code 5V-EU
    Cylinders V 8 in 90° vee
    Capacity 4 litre - 3994 cc - (243.729 cu in)
    Bore × Stroke 87 × 84 mm - 3.43 × 3.31 in
    Bore/stroke ratio 1.04
    Valve gear overhead valve (OHV)
    2 valves per cylinder
    16 valves in total
    maximum power output: (JIS net) 164 PS (162 bhp) (121 kW) @ 4400 rpm
    Specific output(JIS net) 40.6 bhp/litre - 0.66 bhp/cu in
    maximum torque(JIS net) 289 Nm (213 ft•lb) (29.5 kgm) at 3600 rpm
    Specific torque(JIS net) 72.36 Nm/litre 0.87 ft•lb/cu3
    Engine construction light alloy head & block (reported to be 130 kilos[286#s]) for comparison a 1UZ tips the scales closer to 355#s
    compression ratio 8.6:1
    Fuel system EFi
    bmep (brake mean effective pressure) 909.3 kPa (131.9 psi)(with a BMEP of 131 theres some serious room for improvement)
    My goals for the engine: 300hp, 300#/ft
    May 2019
    south Carolina
    Quote Originally Posted by oldeskewltoy View Post
    Engine code5V-EU
    CylindersV 8 in 90° vee
    Capacity4 litre - 3994 cc - (243.729 cu in)
    Bore × Stroke87 × 84 mm - 3.43 × 3.31 in
    Bore/stroke ratio1.04
    Valve gearoverhead valve (OHV)
    16 valves in total
    maximum power output: (JIS net)164 PS (162 bhp) (121 kW) @ 4400 rpm
    maximum torque(JIS net)289 Nm (213 ft•lb) (29.5 kgm) at 3600 rpm
    Specific torque(JIS net)72.36 Nm/litre 0.87 ft•lb/cu3
    Engine constructionlight alloy head & block (reported to be 130 kilos[286#s]) for comparison a 1UZ tips the scales closer to 355#s
    compression ratio8.6:1
    Fuel systemEFi
    bmep (brake mean effective pressure)909.3 kPa (131.9 psi)(with a BMEP of 131 theres some serious room for improvement)
    The intake gaskets are metal but that have a rubber seal ring in the water jackets. I'd say they are quite reusable. And could you give me any insight on wear to fund a service manual? What car do you plan on putting it in?
    oregon
    Quote Originally Posted by osmerjosmer View Post
    I got the engine, the starter, and the manual off Yahoo Japan. I did a search, and I found a similar manual to the one I got... price is a bit $$$ - https://page.auctions.yahoo.co.jp/jp/auction/217949569
    this manual is cheaper - https://page.auctions.yahoo.co.jp/jp/auction/n346477662
    oregon
    not entirely sure... but if the engine's mass pans out, I was thinking of building something along the lines of this.......
    but I don't want to put the cart before the horse... finish engine first, then find a home for it.
    May 2019
    south Carolina
    It's a pretty cubed engine it's about 24 inches tall, long and wide.
    oregon
    24" long too??? from the bellhousing flange to the: front of timing case, front of water pump, front of fan?
    As to height... I'm hoping to avoid a huge hood scoop... something a LOT lower then on this Corona - distributor elimination may be needed
    May 2019
    south Carolina
    Actually its 27" long my mistake and for me I want to go the other route I have a ra29 celica that i want to stick a blower with butterflies out of the hood.
    oregon
    At one time my goal was to mount the 5V in an RA29 too... and it might be again depending on what happens once I have the engine overhauled
    May 2019
    south Carolina
    They just seem to go together perfectly. I'm going for a very American muscle car look.
    oregon
    What are your plans for a transmission?
    I just bought a A340E, with correct bell housing, and torque converter from Yahoo Japan...
    May look at other options, but this was what they came with, and it seemed the easy button.
  1. Toyota Hemi V8 info 5V-EU
    By Joshra23 in forum Tech and Conversions
    Last Post: 21-01-2015, 12:10 AM
  2. Whats better? 2tg hemi or peanut heads
    By mino in forum Tech and Conversions
    Last Post: 22-11-2010, 06:22 AM
  3. 2010 diff centre hemi
    By mick08 in forum Tech and Conversions
    Last Post: 06-11-2010, 06:35 PM
