Results 1 to 15 of 19
Thread: Toyota Hemi V8 info 5V-EU
    Dusty Grease Monkey Joshra23's Avatar
    Default Toyota Hemi V8 info 5V-EU
    I have some pictures and part numbers someone might need, info is pretty scarce. Some of these parts can be used on the 4V-U and 3V
    PARTS LIST
    Look below each picture to match part number. Not in numerical order
    Bolt with washer
    9011910066
    Bolt, stud (for manifold to carburetor)
    9212240832
    Bolt cylinder head
    9212260825
    17174
    Gasket, intake manifold to block
    17174-51010
    5veu .. vg4 #
    17111
    Collector inlet
    17101-52050
    5veu .. vg4 #
    17177
    Exhaust manifold gasket
    17177-52020
    5veu .. vg40
    17177-52021
    5veu .. vg4 #
    17173
    17173-51010
    5veu .. vg4 #
    17141
    Collector outlet
    17141-52060
    5veu .. vg4 #
    not sold
    Collector outlet
    17141-52070
    5veu .. vg4 #
    not sold
    17159
    Bolt, stud (for manifold to cylinder head)
    90116-08077
    5veu .. vg4 #
    Bolt, stud, no.1 (for quarter regulator roller guide)
    9011608287
    Nut
    9017908059
    17141D
    Bolt, stud (for oxygen sensor)
    90116-08128
    5veu .. vg4 #
    17152
    Hairpin collector
    90116-10017
    5veu .. vg4 #
    17142
    Case, exhaust manifold, no.2
    17142-52040
    5veu .. vg4 #
    17142-52050
    5veu .. vg4 #
    1107
    Mounting
    (8709 -)
    11201
    Valve cover
    11201-52023
    5veu .. vg4 #; rh
    Valve cover
    11202-52012
    5veu .. vg4 #; lh
    11201B
    Seal ring
    90210-08002
    5veu .. vg4 #
    11213
    Gasket valve cover
    11213-51011
    5veu .. vg4 #
    Tube / pipe intake air connector
    1787552010
    not sold
    11221
    Separator cylinder head cover no.1
    11221-52011
    5veu .. vg4 #
    not sold
    Bolt head with dihedral
    9161140812
    12108
    CAP ASSY
    12108-49015
    5veu .. vg4 #
    11222
    Separator cylinder head cover no.2
    11222-52011
    5veu .. vg4 #
    11201A
    Nut valve cover
    90176-08007
    5veu .. vg4 #
    12108A
    Gasket (for oil filler cap)
    90301-44049
    5veu .. vg4 #
    11191
    Laying the candle well
    11191-52010
    5veu .. vg4 #
    11247
    Stay, cylinder head cover
    11247-52010
    5veu .. vg4 #
    11101A
    Bolt (for cylinder head set)
    90910-02035
    5veu .. vg4 #
    11122A
    Spring retaining ring
    90520-12049
    5veu .. vg4 #
    11122
    Sleeve valve guide
    11122-51021
    5veu .. vg4 #; std
    11117B
    Tube / plug w head taper screw no 2
    90341-24033
    5veu .. vg4 #
    11117A
    Cork
    90341-24041
    5veu .. vg4 #
    11101
    Cylinder Head
    11101-59086
    5veu .. vg4 #
    11118G
    Pin, slotted spring, no.1
    90254-07015
    5veu .. vg4 #
    11118F
    Tube / plug no 3
    90344-54012
    5veu .. vg4 #
    11131
    Saddle inlet valve
    11131-51011
    5veu .. vg4 #; std
    13961
    Pin, rocker support
    13961-51010
    5veu .. vg4 #
    11115
    Gasket cylinder head
    11115-52020
    5veu .. vg4 #; #, rh
    Head gasket
    11116-52020
    5veu .. vg4 #; #, lh
    11115-52021
    Head gasket
    11116-52021
    11126A
    90520-12049
    5veu .. vg4 #
    11126
    Sleeve valve guide
    11122-51021
    5veu .. vg4 #; std
    1701
    Manifold
    (8709 -)
    11118A
    Tube / plug straight no one
    90334-10002
    5veu .. vg4 #
    11135
    Saddle vent valve
    11135-51012
    5veu .. vg4 #; std
    11158
    Bolt, stud (for rocker support)
    90116-08087
    5veu .. vg4 #
    04111 Engine gasket, full
    04111-52040
    5veu .. vg40
    Engine gasket, full
    04111-52041
    5veu .. vg4 #
    04112
    Gasket engine, the upper
    04112-52040
    5veu .. vg4 #
    Bolt (for backing plate to rear axle housing setting)
    9011910019
    Bolt with washer
    9165160850
    11571
    Case, valve lifter
    11571-51011
    5veu .. vg4 #
    11416A
    Pin / bolt ring
    90253-13008
    5veu .. vg4 #; l = 12.5, od = 8, l = 13, od = 12.5
    Pin, ring (for crankshaft bearing cap set)
    90253-16014
    5veu .. vg4 #; l = 10, od = 15.5
    1302
    Camshaft & valve
    (8709 -)
    11432D
    Seal ring
    90430-14235
    5veu .. vg4 #
    11432A
    Plug (for oil filter cap)
    90341-14032
    5veu .. vg4 #
    11573
    Plate, oil reflector
    11573-51010
    5veu .. vg4 #
    SPARE
    9166140816
    not sold
    11434A
    Pin
    90250-10113
    5veu .. vg40; l = 22, od = 10
    11434C
    90253-16014
    Seal ring
    9043016242
    11434B
    Pin
    90250-10113
    11401F
    Union (for oil pressure switch)
    90404-16205
    5veu .. vg4 #
    11434D
    Pin
    90250-10113
    Pin, straight (for manual transmission case)
    90250-10232
    5veu .. vg4 #; l = 15, od = 8
    11417
    Nozzle, oil
    90915-01010
    5veu .. vg4 #
    11416
    Bolt (for crankshaft bearing cap set)
    90116-12138
    5veu .. vg4 #
    not sold
    Nut
    9017012110
    11401
    Cylinder block (sbor. compl.)
    11401-52020
    5veu .. vg4 #
    11415A
    Tube / plug radiator drain cock
    96432-23814
    5veu .. vg4 #
    not sold
    11415
    Cock sub-assy, water drain (for cylinder block)
    96432-53828
    5veu .. vg4 #
    12101
    Sump oil
    12101-52021
    5veu .. vg4 #
    12151
    Seal. oil pan gasket
    12151-51010
    5veu .. vg4 #
    12101A
    The drain sump
    90341-12012
    5veu .. vg4 #
    12101B
    Gasket (for oil pan drain plug)
    90430-12011
    5veu .. vg40
    Strip
    90430-12019
    5veu .. vg4 #
    O-ring drain plug sump
    90430-12028
    5veu .. vg4 #
    15301
    Oil dipstick
    15301-52010
    5veu .. vg40
    Oil dipstick
    15301-52011
    5veu .. vg4 #
    11452
    Directing the oil dipstick
    11452-41010
    5veu .. vg4 #
    Bolt with washer
    9165140818
    13711D
    Washer
    90201-13366
    5veu .. vg4 #
    13715
    Valve exhaust
    13715-52010
    5veu .. vg4 #
    13741A
    Tappet
    90913-03005
    5veu .. vg4 #
    13741
    Plate valve springs
    13741-51013
    5veu .. vg4 #
    13711C
    Spring, compression (for outer)
    90501-45003
    5veu .. vg4 #
    13711B
    Spring, compression (for c-1 accumulator piston)
    90501-26002
    5veu .. vg4 #
    13711A
    Seal or ring, o (for valve stem oil)
    90913-02046
    5veu .. vg4 #
    13951
    Bracket / mount valve rocker no one
    13951-51011
    5veu .. vg4 #
    13953
    Bracket / mount valve rocker no 3
    13953-51011
    5veu .. vg4 #
    13783
    Rod, valve push, no.2
    13783-52020
    5veu .. vg4 #;
    13781
    Traction valve push
    13781-52020
    5veu .. vg4 #;
    13751
    Tappet
    13750-52020
    5veu .. vg4 #
    13952
    Bracket / mount valve rocker no 2
    13952-51011
    5veu .. vg4 #
    13711
    Valve inlet
    13711-52010
    5veu .. vg4 #
    13511B
    Plug, expansion (for camshaft)
    90331-51052
    5veu .. vg4 #
    SPARE
    9161140818
    13511
    Camshaft
    13511-52030
    5veu .. vg4 #
    13523A
    Dowel crankshaft pulley
    90280-05010
    5veu .. vg4 #
    13523
    Gear camshaft
    13523-51010
    5veu .. vg4 #
    13901
    Valve rocker
    13901-51011
    5veu .. vg4 #
    13801D
    Spring, compression (for rocker arm)
    90501-14546
    5veu .. vg4 #
    13571
    Strip cam
    13571-51010
    5veu .. vg4 #
    Bush
    9538103040
    13902
    Valve rocker
    13902-51011
    5veu .. vg4 #
    13506
    Timing Chain
    13506-51010
    5veu .. vg4 #
    13515
    Gear, distributor drive
    13515-51010
    5veu .. vg4 #
    Washer
    9451201000
    13515A
    Washer, plate (for distributor drive gear)
    90201-10490
    5veu .. vg4 #
    13561
    Chain guide
    13561-51010
    5veu .. vg4 #
    13515B
    90280-05010
    5veu .. vg4 #
    9111151030
    13540
    Tensioner
    13540-51010
    5veu .. vg4 #
    9161140840
    13801
    Valve rocker
    13801-51012
    5veu .. vg4 #
    13803
    Valve rocker
    13803-51012
    5veu .. vg4 #
    9161140812
    13804
    Valve rocker
    13804-51012
    5veu .. vg4 #
    13802
    Valve rocker
    13802-51012
    5veu .. vg4 #
    13011
    Piston Rings STD, set on the engine
    13011-52030
    5veu .. vg4 #; std
    13201A
    Bush (for connecting rod small end)
    90999-73066
    5veu .. vg4 #
    13265
    Bolt
    90910-02044
    5veu .. vg40
    Bolt connecting rod
    13265-52010
    5veu .. vg4 #
    13201
    Connecting rod
    13201-52011
    5veu .. vg40
    Connecting rod
    13201-52020
    5veu .. vg4 #
    13265A
    Nut
    90179-09006
    5veu .. vg4 #
    11046
    Cylinder liner & piston set, mark a
    11046-59045-01
    5veu .. vg4 #; mark a
    Cylinder liner & piston set, mark 2
    11046-59045-02
    5veu .. vg4 #; mark 2
    Cylinder liner & piston set, mark 3
    11046-59045-03
    5veu .. vg4 #; mark 3
    Cylinder liner & piston set, mark 4
    11046-59045-04
    5veu .. vg4 #; mark 4
    not sold
    13041
    Inserts the rod, STD
    13041-52020-0A
    5veu .. vg40; mark a
    13041-52020-00
    5veu .. vg4 #; mark 0
    13041-52020-01
    13041-52020-02
    13041-52020-03
    13041-52020-A0
    13101
    Piston Engine STD
    13101-52020
    5veu .. vg40; std
    Piston Engine STD
    13101-52020-0A
    5veu .. vg40; std, mark a
    Piston Engine STD
    13101-52020-0B
    5veu .. vg40; std, mark b
    Piston Engine STD
    13101-52020-0C
    5veu .. vg40; std, mark c
    Piston Engine STD
    13101-52020-A0
    5veu .. vg4 #; std, mark a
    Piston Engine STD
    13101-52020-B0
    5veu .. vg4 #; std, mark b
    Piston Engine STD
    13101-52020-C0
    5veu .. vg4 #; std, mark c
    not sold
    13101A
    Ring, hole snap (for piston pin)
    90521-25052
    5veu .. vg4 #
    11046A
    Ring, o (for cylinder liner & piston set)
    90301-87001
    5veu .. vg4 #
    13411
    Crankshaft
    13411-52020
    5veu .. vg4 #
    13521A
    90280-05010
    5veu .. vg4 #
    13471A
    90280-05010
    5veu .. vg4 #
    13407
    Pulley crankshaft
    13407-52010
    5veu .. vg4 #
    Pulley crankshaft
    13407-52011
    5veu .. vg4 #
    13471
    Pulley crankshaft
    13471-52010
    5veu .. vg4 #
    11011
    Thrust
    11011-43010
    5veu .. vg4 #; std
    Semiring lock
    11012-43010
    5veu .. vg4 #; o / s 0.125
    925 p.
    Semiring lock
    11013-43010
    5veu .. vg4 #; o / s 0.250
    13521
    Pulley crankshaft
    13521-41011
    5veu .. vg4 #
    13471C
    Bolt (for crankshaft pulley set)
    90105-16010
    5veu .. vg4 #
    11711
    Inserts indigenous STD
    11701-52020-03
    11701-52020-04
    11701-52020-05
    5veu .. vg4 #; mark 5
    11701-52020-06
    5veu .. vg4 #; mark 6
    11701-52020-07
    5veu .. vg4 #; mark 7
    Washer (for clutch pressure lever)
    9020108058
    Bolt (for backing plate to steering knuckle setting)
    9111170814
    Bolt
    9161161020
    11302
    Cover belt
    11321-52020
    5veu .. vg4 #
    1105
    Cylinder block
    (8709 -)
    11328
    Timing cover gasket
    11328-51011
    5veu .. vg40
    Timing cover gasket
    11328-51012
    5veu .. vg4 #
    11302A
    Gland
    90311-45002
    5veu .. vg4 #
    Gland
    90311-45011
    5veu .. vg4 #
    Gland
    90311-45014
    5veu .. vg4 #
    11381
    Locking rear engine seal
    11381-51010
    5veu .. vg4 #
    11381A
    Gland
    90311-85001
    5veu .. vg4 #
    Gland
    90311-85006
    5veu .. vg4 #
    11302D
    Bolt, stud (for timing gear cover)
    90116-10072
    5veu .. vg4 #
    9165160855
    Nut
    9411051000
    SPARE
    9111241075
    not sold
    Washer
    9451201000
    Plate, rear seat back stopper
    9461111001
    Bolt with washer
    9165140828
    11383
    Lining the rear engine cover
    11383-51010
    5veu .. vg4 #
    15102
    Rotor oil pump
    15102-52020
    5veu .. vg4 #
    15413A
    Union (for oil pump outlet pipe)
    90404-20174
    5veu .. vg4 #
    15413B
    Sleeve, ball (for oil pump outlet pipe)
    90410-15006
    5veu .. vg4 #
    15115A
    Ring, o (for oil pump cover)
    96732-24014
    5veu .. vg4 #
    15413C
    Nut, union (for oil pump outlet pipe)
    90402-20053
    5veu .. vg4 #
    15119
    Gasket, oil pump cover
    96732-31065
    5veu .. vg4 #
    15100
    Oil pump
    15100-52020
    5veu .. vg4 #
    15115
    Cover oelpumpe
    15115-52010
    5veu .. vg4 #
    15116
    Bolt oil cleaner compl
    15116-50010
    5veu .. vg4 #
    not sold
    15131
    Valve, oil pump relief
    15131-41010
    5veu .. vg4 #
    Bolt (for intake manifold to exhaust manifold)
    9161140820
    15132
    Oil Pump Spring
    15132-40010
    5veu .. vg4 #
    15104
    Oil Filter (sbor. compl.)
    15104-52010
    5veu .. vg4 #
    15134
    Seal ring
    15134-20010
    5veu .. vg4 #
    15133
    Bolt fixing
    15133-20010
    5veu .. vg4 #
    Clip
    8271122490
    16100G
    Bolt, stud (for water pump set)
    16193-51010
    5veu .. vg4 #; no.1
    16193-52020
    5veu .. vg4 #; no.2
    92122-41040
    5veu .. vg4 #; no.3
    Ring
    9461110800
    16100
    Water pump
    16100-52020
    5veu .. vg4 #
    Retainer ring
    9451200800
    16124
    Gasket water pump
    16129-52020
    5veu .. vg40
    Strip leading. pump. cover
    16129-52021
    5veu .. vg4 #
    16241
    Bolt, stud (for water pump coupling)
    16198-51010
    5veu .. vg4 #
    not sold
    Nut
    9411050800
    Nut
    9412040800
    Washer
    9451100800
    16371
    Fan Pulley
    16371-52020
    5veu .. vg4 #
    Bolt with washer
    9161140830
    16184
    Indicator steuerung
    16184-52020
    5veu .. vg4 #
    16210
    Termomufta fan
    16210-52021
    5veu .. vg4 #
    Termomufta fan
    16210-52022
    5veu .. vg4 #
    16259
    Gasket, blower
    16259-52020
    5veu .. vg4 #
    Default Re: Toyota Hemi V8 info 5V-EU
    Awesome info! Thanks mate. I'd love to put one of these into my sled, or possible the next build.
    Malicious
    No prob mate. Got some other info, was thinking this thread should contain mods eg, chevv dizzy's fit with certain modification etc.
    If you could that would be awesome! Unfortunatly I'll be a while off needing the info but I'm sure others will find it useful.
    Also do you have a list of what vehicles they came in?
    Cheers!
    queensland
    i'm currently doing a full rebuild on one for a hot rod customer
    oregon
    Quote Originally Posted by terryo View Post
    hmmmm, would happen to have the FSM scanned would you???
    New Zealand
    I had no real problems getting a 5V sump gasket for my 4V, apparently the waterpump is no longer available though. Might try a different supplier to see what I can get hold of. Maybe we could merge this with the old V series thread I started?
    http://www.toymods.org.au/forums/tec...surements.html
    Callum
    Quote Originally Posted by WDE_BDY View Post
    Callum
    How's your hemi rolla coming along mate?
    New Zealand
    Slowly at the moment, will be putting some work into it this week hopefully. Need to get front suspension all set up before it can go back for some more panel work.
    Callum
    Terryo,
    I dont suppose you have any workshop manuals or info for these in a shareable format do you ?
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    oregon
    Terryo,
    would love this as well....
    Oct 2009
    Yeah, $100 to get it scanned lol
    queensland
    i dont have one. i've jsut learned as I go. now had to do a few of them. nothing is very unusual (in engine mechanics) so a manual is not really needed.
    I'm still chasing a bellhousing...cash waiting
    Nov 2011
    A green Goliath at last years meguires moto x had one of these motors fitted
    Running a carby
    Surely there is info on these in the USA
    Just find the hemi they came out of and get the workshop manual for it
    There is shitloads of stuff for USA cars
    dumbass,
    As far as I am aware the engine was not fitted to anything sold in the USA either. Its pretty much a JDM only powerplant
    Its a Toyota designed and built Engine.
  1. Toyota FWD/RWD transaxle info...
    By Rex_Kelway in forum Tech and Conversions
    Last Post: 11-01-2013, 09:52 AM
  2. Toyota Brake Info
    By bobob in forum Tech and Conversions
    Last Post: 21-07-2006, 11:03 AM
