Results 1 to 10 of 10
Thread: JZZ30 1J into my GZ20 1GGTE I've started help !!!
    Junior Member Backyard Mechanic cptsideways's Avatar
    Dorset
    Default JZZ30 1J into my GZ20 1GGTE I've started help !!!
    I've started on my engine swap for my D1 Drifty GZ20 & I've only a week to complete it eeek. Have a nother round of the D1 on July 1st.
    I'm going to need some help on this folks!!
    What I'd like to know is how much of the JZZ30 wiring do I actually need to make the thing run? its a track car mostly so not too fussed about niceaties for the next week or so anyway. The JZ subframe/crossmember looks the same as the MK4 Supra subframe & I was assuming I can unbolt the entire thing suspension arms & all.
    Most of the links I've found don't relate to this engine model swap is there much difference?
    Dorset
    Default Re: JZZ30 1J into my GZ20 1GGTE I've started help !!!
    Well I've been busy mapping the wiring the loom on the the GZ dashpod, all seems to make sense now all I have to do is make it match the JZZ30 loom lol
    I've found the JZZ30 wiring diagrams but has anybody else done anything with a JZZ30 loom/swap before could do with asking for some tips guys.
    Sliding his D1 Soarer around the UK
    currenty fitting a Jzz30 1J into my VL Commie, just about finished actually, got it wired and running tacho,temp and warning lights working.
    what parts did you need to know
    Dorset
    Quote Originally Posted by rogue-vl
    AHAHAH
    Thats exactly the stuff I need
    If you have any info I'd be more than pleased to see it, I'm sat at my desk here now with 2 almost complete looms, 28 pages of pdf files & my heads going all wobbly
    So yes any help appreciated!!!!
    What I need is the source or plug point on the loom for tacho, oil, warning lights, temps etc etc just the basic stuff will get me up & running
    Dec
    Quote Originally Posted by cptsideways
    AHAHAH
    Dec
    For things like the temp sensor and the oil light it can be easier to simply get the multimeter out and trace the wire!
    Dorset
    You've obviously never seen a JZZ30 wiring loom!!! theres over 400 different connections on the dash loom alone, that connects into the engine left loom & the engine bay right loom, each with hundreds of connections on. Yes I'm only trying to trace about 10 wires but its the process of elimination thats causing the hassle.
    Take a look at this to get an idea, this thing aint no points & condensor job!!!
    http://www.1jz-gte.us/documents/SubDocs4/Soarer2.pdf
    meh dash loom.
    just hook the enigine loom into your exsisting dash loom.
    too much work unless you fabed in a complete jzz30 dash.
    Black Betty >HERE!<
    (\__/)
    Ok I'll bite, for things like the temp sensor and the oil light it can be easier to simply get the multimeter out and trace the wire!
    Yes, I am being helpful - disconnect the engine loom from the dash loom and use the MM. How do you think the rest of us do it?
    Factory wiring diagrams help but are only a luxury - you still need to understand them and apply them to the loom, and you still need to check with a MM if the diagram is correct, so if you only need 3 wires, the MM can be quicker.
    Mos.
    Quote Originally Posted by Mos
    Mos.
    Mos and I can't both be wrong
    Oh and I have a JZZ30 engine + loom in my car, so I think I can qunatify that I have seen a JZZ30 loom
    Dorset
    Ok guys I took your advice, I tried it your way AND IT WORKED !!, ok so I dug out the JZZ30 EFI control relay loom, much easier to find manually than trying find connections on the the loom diags.
    So I'll eat my hat guys & cheers for the perserverance in convincing me.
    Have sorted the following ready for connecting up:
    Alternator connections
    Engine side efi relay engine-fusebox from JZ
    Next up
    Oil, tacho, starter, power, ign switch etc
    Cheers guys
  1. GZ20 1ggte-1jzgte soarer wiring HELP!!!!
    By ONETEN in forum Tech and Conversions
    Last Post: 01-07-2006, 09:49 AM
  2. 1GGZE SC on a 1GGTE?
    Last Post: 22-06-2006, 08:15 PM
  3. GX81 & GZ20 1GGTE gearbox's the same ???
    Last Post: 04-06-2006, 10:45 PM
  4. Help 1JZ JZZ30 Manual into a GZ20 1G Manual
    By cptsideways in forum Tech and Conversions
    Last Post: 28-04-2006, 04:58 PM
