Results 1 to 6 of 6
Thread: mx83 1uz info needed
    Apr 2016
    Post mx83 1uz info needed
    im thinking about doing a 1uz into my 1990 mx83 Cressida
    I know I need to do the exhaust headers to pass steering rack
    I'm going to buy the aftermarket engine mounts kit
    ive heard at using the 7m auto box with 1uz bellhousing and torque converter to be able to use stock box n tailshalft
    and wanting to get wiring diagram for mx83 computer pin output and a celsior computer pin output
    any information will be helpful thanks
    Feb 2016
    Default Re: mx83 1uz info needed
    Any reason why you wanted to go 1UZ?
    Or do you have a cheap halfcut?
    Guessing you are -
    ‎Daniel Tomlinson‎
    Facebook hahaha looking for 1uz and A340 haha
    Apr 2016
    only cause I can get a complete front sump v8 celsior for $1000 and has other parts I can sell off it
    and always wanted to do a v8 Cressida but if I cant get any information ill most likely go na 2jzge in it
    Drivers exhaust will need modifying.
    (depending on which model you get passenger may also aswell)
    Apr 2016
    yer know that man mite have found myself a set of extractors that hug the motor really good for cheap
    Feb 2016
    Do not bother with the 2JZGE - Waste of time man
    Either go the GTE or the 1UZ
    I am building the GTE now... - http://www.toymods.org.au/forums/thr...Cressida-Build
    1UZ Will be a heap of work due to fitment work and custom adaptors and mounts...
    Either way you need to budget for at least 5-7K in the conversion... Its not a weekend job, Literally nothing will go right.
    1UZ will be easier due to no turbos... No Pipiing, No Cooler ect ect
  1. mx83 7mge manual conversion info needed
    Last Post: 06-04-2016, 02:32 PM
  2. TPS info needed (2jz)
    By Savtec in forum Tech and Conversions
    Last Post: 18-02-2012, 01:22 AM
  3. 18rgeu ECU info needed
    By cameron lt2000 in forum Tech and Conversions
    Last Post: 23-07-2008, 01:34 PM
  4. 1uz-fe + 3uz info needed +man gbox
    By bje10s in forum Tech and Conversions
    Last Post: 14-01-2008, 06:53 PM
  5. 3rz-fe Technical info needed
    By -==L=a=N=c=E==- in forum Tech and Conversions
    Last Post: 09-05-2007, 10:13 PM
