Results 1 to 7 of 7
Thread: TPS info needed (2jz)
    Default TPS info needed (2jz)
    Hey guys just wiring up my car with the 2jz and i cant figure out the TPS, i need to know what wires are what, like power, earth, sensor, etc.
    and oxy sensor it looks like its a factory sensor, power, signal, ground.
    Any help would be good,
    Cheers Gav
    May 2007
    Default Re: TPS info needed (2jz)
    Quote Originally Posted by Savtec View Post
    Cheers Gav
    will have a look tonight if i remember...
    when wiring up to a microtech for the TPS ive only used 3 out of the 4 wires... GND 12v and 5v... just cannot recall off the top of my head which goes to which...
    as for the o2 sensor i dont run one so im not sure...
    thread dig! I also need to know this info as the car i just bought is reading the tps like a switched type and would explain why it keep fouling up the plugs
    anyone know which colors are which? or number 1 - 4?
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    i found the info, for anyone else wanting to know:
    5v - blue/red wire
    signal - yellow
    ground - brown/black
    12.4 @ 110mph
    thread dig x2
    so what does the fourth wire (red) do then? ...is it just "throttle closed" signal?
    our tps is behaving oddly... when its in the closed position it gives the correct signal (voltage = ~.1v) but when we start to open it, it jumps straight to 5 volts... its not linear at all.
    we know its not the tps because we tried the tps in another car and we get a linear reading, so we think it might be a wiring issue.
    any idea's or can someone at least tell us what the red wire is for?
    JZA70|R / 12.45 @ 111 mph.
    Nov 2011
    tps has 4 wire in one row
    one end will have a brown wire
    this is ground or sensor earth next wire after brown is idle signal not used on aftermarket ecu
    next one after idle signal is tps voltage signal this is the variable signal
    the next one after that which is the other end of the plug is the 5 volt supply
    yep your spot on. we got it all running sweet this arvo.
  1. Electronics help with TPS circuit.
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 01-06-2010, 10:32 PM
  2. 18rgeu ECU info needed
    By cameron lt2000 in forum Tech and Conversions
    Last Post: 23-07-2008, 01:34 PM
  3. 4agze TPS - fault & setup
    By AE101LEV in forum Tech and Conversions
    Last Post: 24-10-2006, 07:36 PM
  4. 4AGZE to 4AGTE in AE86 Info needed
    Last Post: 17-06-2006, 12:15 PM
  5. Carbon canister purging tech info needed
    By nick.parker in forum Tech and Conversions
    Last Post: 30-03-2006, 08:03 PM
