Results 1 to 13 of 13
Thread: 3rz-fe Technical info needed
    Rosewood
    Default 3rz-fe Technical info needed
    Hey guys,
    I've been scouring the web for 3rz-fe (Hilux 2.7L Engine) related information. Everything from pinouts to rebuild details, could anyone help me out with this information please? Also any information on 1999 Hilux body/electrical guides.
    Ideally i'd like to get an online database happening much like my GT4 information.
    Any help appreciated.
    Default Re: 3rz-fe Technical info needed
    pretty damn good motors, tell us what detaisl u have and what u need
    we do a few at work, the main reason we get them is cause they have 500,000k on them, not cause they fuck out regularly.
    The conrods are huge, as is the crank and mains, the top end is shim over bucket, 4 valve per cyl pent-roof combustion.
    what else u need
    The boobs are back
    can anyone tell me the injector size in cc ?? also is the fuel system run a return line or not and if it does is the fuel reg rising rate ??
    also standard compression ratio ??
    thats all the info i need
    shannon
    Junior Member Backyard Mechanic 71RA20's Avatar
    California
    California
    Also found this wiring diagram
    http://www.norcalttora.com/~mike/pdf/3rz-fe.pdf
    California
    "1400 HP 3RZ"
    This website is very helpful with 2RZ and 3RZ motors, parts and info.
    http://www.customtacos.com/forum/sho...&highlight=3RZ
    Cheers, Johnny
    Rosewood
    71RA20 thanks mate, that wiring diagram is a big plus +rep for you.
    Mr DOHC: this motor is my next big project, as the GT4 has been sold. Hopefully wish to test the limits of a stock bottem end 3rz, and then push for more. Details to follow once they come.
    stock bottom end has been known to handle 1200hp+ {forged pistosn tho}
    dependant on model, they either have 8.5 or 9.0:1
    they are a workhorse so the cant have too higher-a CR or they'll ping
    The boobs are back
    FYI
    richard, the guy who owns ARE has a turbo one in a S13 180SX, 850-odd-rwhp
    The boobs are back
    Rosewood
    Mr DOHC: i am aware as such, and the viehcle im looking to purchase already has a worked 3rzfe in it. Stock bottom end, but ported head, custom inlet/exhasut manifolds, running a t3/t4 turbo, and has a best power output of 360rwhp. Which is impressive.
    Hopefully Mr BankMan will lend me the required money to aquire said viechle.
    Check this out. Its for the Tacoma (USA Hilux) its got bucket loads of PDF's on the 3rzfe. Mine is in the process of getting turbo,d at the moment
    http://misc.mmdsi.net/tacoma/tacoma-manual/
    Rosewood
    Quote Originally Posted by fezi
    Excellent information. +rep for you
    User Conversion King
    NWA
    as requested by barned
    hello
  1. Toyota Crown MS63 Custom Wagon Info
    By TheToyman75 in forum Tech and Conversions
    Last Post: 28-09-2007, 12:31 PM
  2. 4AGZE to 4AGTE in AE86 Info needed
    Last Post: 17-06-2006, 11:15 AM
  3. AE86 Axle upgrade needed...
    By irishtwincam in forum Tech and Conversions
    Last Post: 07-03-2006, 06:19 AM
