Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 76 to 90 of 138
Thread: 1st gen celica susp. and steer and struts (strut tops - are ta22 and ra28 the same?)
  1. #76
    RA23 + 3SGE Beams Backyard Mechanic Major Clod's Avatar
    Default Re: 1st gen celica susp. and steer and struts (strut tops - are ta22 and ra28 the same?)
    Hmmm looks like you're right... Koni 8241-1140Sport have also been suggested. However, they are 2 inches shorter (19inches) but travel is only .25 inches less. Might be a bit useless if you've already moved your lower mounts however.
  2. #77
    At full droop, how captive should the springs be? Just snug in there, or should they have quite a bit of tension on them?
    1996 FZJ80 Landcruiser.
    Email : [email protected]
  3. #78
    Just captive should do it. Any more and you restrict the amount of movement you have should your car leave the ground, and that can cause extra stress on other components. It also reduces the impact when the suspension tops out.
  4. #79
    Seems series 1 rx7 are around the right length.. Just the bottom mounting is slightly different, the centre hole is larger and the width is different.. Nothing a custom bush probably couldn't fit though.
  5. #80
    hey mate,
    the number pressed intothe bottom of my rear shocks is - 80 2299
    hope that helps.
    Stew
  6. #81
    Thanks mate, that is a Torana shock, also used in Nissan 180b/200b haha.
    I'll check out its length to see if suitable.
    Joel
  7. #82
    any luck on that length checking joel?
    P.S cheers for all the part numbers guys!!!
  8. #83
    Junior Member Grease Monkey 9000rpm's Avatar
    Tasmania
    Quote Originally Posted by TurboRA28
    I'm making things a bit harder wanting the original length shocks as I moved the lower shock mounts down on the diff to keep the springs captive.
    RA28 rear shock
    549mm open / 339mm closed.
    Top mount= 11.11mm dia pin, 54.61mm pin length
    Bottom mount= 15.88mm pin, Bush width 36.58mm free, 33.27mm compressed
    90 series Prado 4WD rear
    538mm / 332mm
    Top mount= 11.11mm dia pin, 60.20mm pin length
    Bottom mount= 19.05mm pin, Bush width 44.45mm free, 38.10mm compressed
    Will need a sleeve pressed inside the lower mount, and a modified lower mount to accept the wider bush (or narrow it with a grinder )
    Bilstein p/n BE5-2351 or BE5-2741. Not sure if these are longer than factory length though.
    Matt
  9. #84
    Not having any luck on finding the specs on the Torana/180B shocks that Stew is running. I've got a catalog of shock specs but its US, and Torana/180B don't seem to be listed there which is understandable.
  10. #85
    south australia
    isn't the torana based on an Opel of some sort? are you able to possibly find it in a european version?
  11. #86
    Black Betty >HERE!<
    (\__/)
  12. #87
    Tasmania
    The listing i have shows 180B/1600 uses the same shock as a RA28.
    XU-1 Torana 501mm/305mm
    GS006 is LH Torana rear. I bought some Koni's for a workmate for his LH through Toperformance last year, $199 trade I think.
    Matt
  13. #88
    Seems GX006 suits RA28, Torana, 1600, 180B etc .. 501mm is a bit shorter than standard RA28 though?
  14. #89
    I dont quite get why Koni's catalog lists part number 80229 for Torana, 1600, 180b. But not for Celica?
  15. #90
    User Conversion King
    NWA
    Quote Originally Posted by 9000rpm
    RA28 rear shock
    538mm / 332mm
    great info!
    you wouldnt happen to have the RA40 celica specs there at all also? coupe if that makes any difference (shouldnt though).
    just want to confirm they are the same on the 23/28 and 40
    hello
  1. Building an Australian RA21 (18RG + TA22)
    By ace in forum Tech and Conversions
    Last Post: 04-07-2006, 10:09 AM
