Results 1 to 15 of 30
Thread: high oil pressure. aw11 20v turbo, no oil cooler
    Default high oil pressure. aw11 20v turbo, no oil cooler
    I've noticed my oil pressure is getting much higher now according to the standard aw11 guage. (it sits around where I have the red line marked in the photo cruising at 3000rpm)
    Previously it used to sit between lines 2 and 3 in the pic when cruising at freeway speeds, and somewhere between 1 and 2 while idling.
    This was with the basically standard blacktop 20v, with the aw11 oil pressure sender screwed into the block. It was running an oil cooler off a sandwich plate underneath the oil filter.
    Now with the turbo setup, its getting up above line 3 when cruising at only 3000rpm - its near the top of the guage now.
    The oil supply for the turbo is coming from a T-piece which is now between the oil pressure sender and the block, and I had removed the oil cooler for simplicity.
    After some sustained spirited driving using revs up to 8000rpm and ~6psi it has developed an oil leak - I havn't established where from yet, but possibly from around the T-piece, or the fitting that feeds the turbo.
    -could the pressure be high due to high oil TEMPs? from running no oil cooler? even though its very high cruising on the freeway.
    -can anyone estimate from the aw11 guage how high is too high with oil pressure.
    -could it be that it was actually lower than it should be previously when I had the oil-cooler-sandwich plate setup, and now its actually where it should be for a blacktop 20v and just looks high on the aw11 guage.
    If anything, the engine sounds LESS rattly than it did before at idle
    perth
    Default Re: high oil pressure. aw11 20v turbo, no oil cooler
    oil pressure will decrease with temp.
    get a mechanical gauge in psi, and screw it in and check the pressure with that gauge.
    could be faulty sender unit or gauge.
    Jul 2007
    As above. Another thought here is if you are getting more blowby than your breather can cope with then it can increase the crankcase pressure. Which may show up on the gauge.
    alright, I'll have to get another oil pressure guage, where would you normally screw it into? same spot as factory oil pressure sender? in this case the t-piece coming off the block?
    if its more blow-by, would that still occur under light throttle - light load cruising - steady speed? or only under some load?
    My crankcase breather filter isn't soaked with oil yet. I realised the PCV valve on the crank case is only a one way valve, allows air to be sucked out of the crankcase, but blocks up when pressure is against it the other way, so I wouldn't expect my 6psi boost to be a problem there.
    Oct 2009
    Sendor or the gauge is probably a little fucked.
    Put a mechanical gauge on
    Jul 2007
    yes can tee into the same spot. and no if it's happening at idle etc then it obviously wouldnt be from boost.
    Gettin old 1st year Apprentice
    Back in the Gong
    Have you changed the oil and you are now running a thicker oil?
    Sep 2007
    Georgia
    compression and leak-down test required to insure that blow-by is not from worn rings. Any restrictions in your oil supply to that sender will result in a high pressure, coking from the oil return from the turbo, dirty oil filter. That will cover all of the possibilities.
    I found out the main cause of the oil leak. The broken thread bit was screwed into the block.
    Guessing the: sender-tpiece-block setup couldn't handle the vibrations etc.
    Since its a only a 1 wire oil pressure sender, I guess it earths through the thread in the block.
    Adding this t-piece was one of the changes from before-after, so perhaps the t-piece and thread tape cause more resistance in the circuit and caused the reading to be higher.
    I just temporarily have the turbo oil feed screwed straight into the block with no leaks, but I'll have to work out a better setup.
    Will maybe look at doing the oil filter relocation and tee-ing off those lines for turbo oil feed, and plumb in an oil cooler while I'm at it.
    Mar 2011
    make sure you use 1/8 BSP fittings, not 1/8 NPT. common mistake for 4age owners. looking at your pic, it looks like only a couple threads of that adapter have screwed into the block, this is normally the case when you screw in a 1/8 NPT fitting into a 1/8 BSP tapped hole.
    you can keep using the set up you have pictured if you add a braided line from the t-piece to the oil pressure sender. mount the oil pressure sender to the block somewhere using a p-clip, or even onto the chassis if the line is long enough.
    SHEPPO..
    Quote Originally Posted by SHEPPO3930 View Post
    Thats interesting, and appears that may have been the problem all along. I knew it didn't screw very far in to the block, but figured it was mainly from it being a tapered thread.
    Now I'll need to look at getting some 1/8 BSP fittings, maybe I can get a 1/8 BSP to 1/8 NPT joiner and still use the same T-Piece.
    I'll also look at remote-mounting the sender as you've suggested.
    Jul 2007
    yep this has happened to a few people. you need a 1/8 BSPT thread into the engine block. And it is preferable to either brace the T piece or mount it remotely, as the extra leverage snaps them. has happened to a few people already as mentioned.
    also yes the oil pressure sensor grounds through the block so a change in resistance will cause a change in the reading. you should also use sensor safe threadlocker.
    Tallahassee, FL USofA
    Yes, the electric circuit goes through the sending unit to the block, but if there was actually extra resistance from tape/whatever(there ain't), then the gauge would be showing a lower reading, cause when it has zero resistance is when the display will be high/pegged.
    Jul 2007
    the aw11 pressure gauge is funny. the test in the manual does not specify a high/low resistance. the test for it is to wire a test light in series with the power to the sender and it should then flash variably with reference to engine speed. thats what the bgb says anyway.
    Oct 2009
    One will go into the other ok but not really the other way around.
    Although if you use a brass fitting (and because pipe threads work essentially by cross threading) you will get away with it 9/10 and never have a issue.
  1. High fuel Pressure 4age
    By Wedged'86 in forum Tech and Conversions
    Last Post: 30-07-2013, 05:35 PM
  2. 4age oil cooler pressure relief
    By fandio in forum Tech and Conversions
    Last Post: 17-06-2011, 07:19 PM
  3. 3sgte high oil pressure????
    By paulioq in forum Tech and Conversions
    Last Post: 28-02-2011, 12:19 AM
