Results 1 to 15 of 16
Thread: 1UZ manual conversion options
    Default 1UZ manual conversion options
    Hi guys, long time no post. I've been out of the scene for a number of years now and I find myself wanting to finish my Hilux 1UZ + auto project, but I'm starting to think switching to manual might be easier than trying to make the A340 do what I want. To that end, what are the best option(s) for running a W5x behind a 1UZ these days? I recall there used to be several options and some were pretty crap, but my old brain can't remember things like it used to.
    I'm also open to other options like Holden 5-speeds or whatever, as long as it works and doesn't cost a fortune. There are no plans for forced induction so I don't need anything ridiculously strong.
    So school me, what's the state of play in 2014? Thanks!
    Sep 2009
    Default Re: 1UZ manual conversion options
    4wd or 2wd?
    Sorry should have mentioned that, it's a 2WD Hilux RZN149. Currently has an A340 installed, but with no electronics.
    Junior Member Grease Monkey Pagie84a's Avatar
    Feb 2012
    Sa
    I just got a chromoly fly to suit w58 from someone here for 300 my plan is to get ebay belhousing
    Junior Member Backyard Mechanic Valkyrie's Avatar
    Tasmania
    Probably best to jump onto soarecentral and have a browse.
    The two options I've seen in person are the W5# and the R154. I have also seen race stuff, but that is obviously not relevant. The other option people look at are T56 gearboxes (6 speed) from Commonwhores and the like.
    [ $[ $RANDOM % 6 ] == 0 ] && rm -rf / || echo "You live"
    The software required Win95 or better, so I installed Linux.
    4AGZE into TA22 http://www.toymods.net/forums/showthread.php?t=16775
    1JZ powered RA60 https://www.toymods.org.au/forums/th...light=1jz+ra60
    Bellhousing from crs
    Clutch to suit flywheel. Townace would suit spline.
    W58
    Custom tailshaft
    Jul 2007
    T56 is a headfuck with wiring it to a stock ecu and dash and I wouldn't bother unless you needed it for the strength over a w box
    Tasmania
    There is also a bellhousing option for R151s and the like. They have a different input shaft length.
    If you aren't chasing power W5# for sure.
    You can also find bellhousing options for RB25DET gearboxes as well...
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    Always been a fan of the Niteparts bellhousing and flywheel from NZ. Have had a few and never had any problems at all. These are available for the W and R series transmissions.
    Feb 2012
    Sa
    Spoke to a guy at a toyota wreckers today and he said a fly from a hilux surf v6 bolts onto the uz and recomended an r150box apparently strong as r154 but with diiff input shaft length and gearing but cheaper. Can anybody confirm
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    I used a thailand ebay spec bellhousing and flywheel, the clutch that this flywheel uses is from a 2KDFTV and is a 10.5 inch clutch disc
    My Rides:
    1x Brown St141 corona csx. powered by a gen 2 3sge, 1x RT142 turbo 1UZ, cd009 and G series, 1x Gj Sigma Scorpion injected and turbo'd, 1x KE30 2TG, w58 and F truetrac, 1x RT104 18RG, w58 and F truetrac
    Feb 2013
    Quote Originally Posted by Pagie84a View Post
    I've got a R150F box behind my 1UZ in my RN105R 4x4.
    I used the stock 1UZ bellhousing and coupled that to the box via an adaptor plate
    I dont believe there is a factory flywheel considering there is so many aftermarket options available, but happy to be proven wrong.
    Bazooka could not see a listing for a 1uz bellhousing on the niteparts website, they do however list a flywheel.
    the other flywheel ive heard can be used is the 3sgte, but it requires the pcd to be changed to actually bolt up
    My Rides:
    May 2006
    Quote Originally Posted by bmxer54 View Post
    Sorry try this link
    http://a1turbos.co.nz.198-144-188-11...at=Bellhousing
  1. ke20 ke25 T50 hydraulic clutch conversion options
    By aspheric in forum Tech and Conversions
    Last Post: 16-12-2011, 05:38 PM
  2. Replies: 4
    Last Post: 27-11-2011, 09:43 PM
  3. gearbox options for engine conversion
    By lowlux69 in forum Engine & Driveline Conversions
    Last Post: 10-11-2007, 03:15 PM
  4. AE86 Gearbox Conversion Options
    Last Post: 20-03-2006, 01:30 AM
