I know nothing about these type engines so I googled the capacity & it and it says the 2L is around 2.4 litres & the 3L is around 2.8 litres, I think personally the engine is probably to small Now & is lacking the grunt to pull the car along in 5th gear or the 2L engine you fitted could have some issues ?? ..
You could change the diff ratio to improve it but then fuel economy is going to suffer & also your speedo is then going to be out too, as I see it you are chasing your tail rather than fixing the main problem being the engine, maybe if the motor & injection pump etc checks out ok you could Turbo the 2L motor, but again more costs ...
