Results 1 to 5 of 5
Thread: Strange gearing problem?
    Jul 2008
    Finland
    Default Strange gearing problem?
    Hello!
    I want to ask every one here that have the Aristo engine and tranny in a Soarer. Have you had the problem like me? I have a problem that my car change gear as normal sometimes. And then sometimes it will not change gear i D. So i have the 1 gear and 2 gear. But when i go to D it will not change anything. And this happens just sometimes. No diffrense about when it's warm or cold.
    I use a stand alone system of Aem. But my first thought is that it's some electric cable that have some problem or something. For why can it drive normal some times and some times it will not?
    Cheers Nicke
    Default Re: Strange gearing problem?
    JDM 2JZGTE Autos have the line pressure controlled by the ECU, not a cable.
    One thing to check is that the AEM has the ability to control the line pressure... I think it does but it's been a while since I looked at it. (I can't remember but I think USA 2JZGTE autos had a cable for line pressure?)
    Other things to look at are wiring or ECU.
    Wilbo's JZA80
    Wilbo's JZZ12
    Jul 2008
    Finland
    A line Pressure you say. Maby shall i see what it show. The other thing is the Wiring diagram. My first thaught was that it could be some of the cabels that have a problem. But witch one? i should be some of the one that go for 3-4 gear. Everyone is in place but i think some of them can be damage.
    But why shall it work some time and other times it will not work? this is strange i think..
    Jul 2008
    Finland
    Now, we have tried the line pressure and then tried to make more pressure to get an aswer if it was that problem. But it didn't get any results.
    So now i need some new answer of what it can be?
    And do any one have The wiring diagram for the gearbox and point of the D on the gearbox wiringdiagram.
    Jul 2008
    Finland
    Nobody that have had some kind of same issue? And nobody have some solution to the problem? And i don't want to get the mane cabel from the gearbox removed because i did burn one gearbox after just 3 month.
    Is there any way to check the main cabels to D if there work fine?
  1. Strange light problem with ae86 dash
    By Intense in forum Tech and Conversions
    Last Post: 25-07-2007, 12:37 PM
  2. Odd 7M-GTE surging/stagger problem
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 22-06-2007, 03:38 PM
  3. Boost problem
    By eighty-eight in forum Tech and Conversions
    Last Post: 21-06-2007, 02:49 PM
  4. thermo fan problem
    Last Post: 03-12-2006, 11:45 PM
  5. Strange login problem?
    By Big T in forum Toymods Car Club Membership and Feedback
    Last Post: 08-12-2005, 11:08 AM
