Results 1 to 10 of 10
Thread: mx32 diff swap
    Dec 2011
    Default mx32 diff swap
    I have a 77 mx32 with a 1jz jzx100
    Need help with diff
    what will bolt straight in the place of the old one
    Trying to keep it 4 stud still with disc brakes
    Any help or feed back would be cool
    Default Re: mx32 diff swap
    Pretty sure you have an E series diff from factory.
    Pretty sure nothing will bolt straight in to replace it (other than another E series ).
    I can't think of any Toyota 4 stud options that would be an upgrade without changing stud pattern...?
    So Hilux diffs are an option for you, and the old Volvo diff is prbly worth a look also...
    Wilbo's JZA80
    Wilbo's JZZ12
    Dec 2011
    Hi thats good info my plate has a few stampings onit
    Fz41
    A40
    E313
    A23
    I have know way of tell what they stand for.
    I will look into the volvo diff
    Thanks for the info
    My translation is the following,
    Trim: FZ41
    Gearbox: A40 (3 Spd Auto)
    Diff: E313 (3.909 ratio, 2 Pinion LSD <see here>)
    Colour: A23
    Going off the plate you should have an LSD already (I've never actually seen anything with an E series LSD!). That said the diff could have been replaced over the years with an open centre...might be worth looking into
    Wilbo's JZA80
    Wilbo's JZZ12
    Dec 2011
    Ok cool thats interesting it has a
    lsd so would that be strong enough to handle
    The 1jz or should i do a bit of research into the
    Volvo diff.
    Or should i just change all bushes and rubbers
    And try it
    Aug 2009
    The E diff is 7.1" crownwheel, with some slight mods, an F series 7.5" housing could be fitted from an old MA47 or easier one from and Corona MK11. Then it's a step up to Hilux with 8" LSD but has 5 studs and gives you more choices in rims.
    Rgds, Willofan
    Dec 2011
    Ok so the hilux does it bolt in or need fab to fit
    Thats the thing was trying to keep 4 stud so
    Front end didnt need upgrading
    In saying upgrading front would r31 skyline or pintara
    Be a good way
    I'd expect pretty well any diff upgrade will require you to cut off your existing diff mounts and weld them to the new diff. So if you put new bushes in, you get to take these with you if you upgrade the diff.
    I'd spend the time to find out if you actually have an LSD, and if it's working then see how long it lasts I say!
    FYI MA4x (MA45, MA47, etc) are super rare, and the diffs are super popular, so you would be very lucky to find a diff from one! (Same goes for Corona MKII) in my experience...
    Front upgrade is a whole new thread...(search MA61 5 stud if you want, 99% sure MX32 has the same stub axle... hint MS65 hubs are an option...)
    Wilbo's JZA80
    Wilbo's JZZ12
    Jan 2013
    Or you could just bolt in MX83 front end and get 5 stud bigger brakes and everything.
    I have two sets of coilovers AE86 and MX73 on my X3 so there is lots of options out there for upgrades and conversions as such.
    I used AE86 whiteline adjustable arms for my MX32 i wonder if someone may have an already converted E7/E8 diff you could buy that maybe would bolt on?
    CISCOKIDS
    The Gentlemen's Club
    Midnight Rocker
    Dec 2011
    Ok i can get hole car of that type to use front end
    So would the diff be 1400 wide and have the
    2 upper control and 2 bottem control with panard rod
    If so that would be a better way
    Iv been on this build for 3 yrs just have not much time
  1. alternative diff centre for mx32 cressida?
    By 5M_MX32 in forum Tech and Conversions
    Last Post: 11-10-2012, 10:04 AM
  2. RT142 OD auto into mx32 - swap bell?
    By markiitourerv in forum Tech and Conversions
    Last Post: 06-02-2010, 12:06 AM
  3. diff swap for Ra23
    Last Post: 01-12-2006, 02:16 PM
