Results 1 to 15 of 21
Thread: diff swap for Ra23
    Default diff swap for Ra23
    some time ago I was speaking to someone about a diff swap for an ra23/ra40, he mentioned to me that one of the rwd celica's above the ra40 model the whole diff could be swaped over, apparently the diff bolts straight in, same mounts and everything and you've got a disk brake rear end! Anyone know if this is true and which diff he was talking about???
    Default Re: diff swap for Ra23
    Probably the MA46 Supra, some of which came with an F series diff and disc brakes. It will fit with minor mods (from memory two of the trailing arms have to be bent a little), but it's a moot point because you'll never find one.
    Your probably better off putting in a Hilux diff...
    ([][][]II--LT--II[][][])
    volvo ftw!...bigger stronger axles then the hilux,.....
    Junior Member Backyard Mechanic strat's Avatar
    Jun 2006
    s.a
    Hi. Just use your t series diff with a AE86 LSD center you can get them new quite easy and your cown wheel will fit and it will bolt in. Then you can fit rt141 rear brakes they to just bolt on but you have to use a the corona retaining plates. i use this set up on my race car caus its cheap quick, easy and it is stong enough. If you dont have more than 300 bhp i dont think its worth mucking around with bigger diffs ie hilux etc
    S.M.R
    There is a method in the madness
    Quote Originally Posted by strat
    also depend on what he is using it for,
    that might help determine what u should use,
    engine....
    power...
    purpose...
    Junior Member Backyard Mechanic SIKTOY's Avatar
    The RA40 (1410mm) diff is wider than the RA23 (1365mm) one
    If you go with the Hilux diff your tail shaft will have to be shortened 30mm to fit and the diff will most likley be 1410mm long so it will have to be shortened to 1365mm to fit
    Ben
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
    Precisely. If for example the vehicle in question has a stock 18R-C, a Hilux or Volvo diff conversion would be massive overkill and would make the car noticeably slower for no reason.
    south austraila
    All you need to do is get a set of RT141-142 rear disc's and fit to your RA23 diff.
    Here is a pic of an RA23 diff, with 142 disc's , & RA60 diff centre ( 3.9 ratio )
    This is a plug & play ( only need to file the bush mounts to hold hand brake cable )
    Project: '82, GA61 XX
    Long Time Reader Backyard Mechanic willwal98's Avatar
    Actually while we are on the topic of mating the right motor for the right diff. I've got a stock gen 3 1ggte in my 28 and i'm on my second center and it's noisy. I can't seem to decide on a diff. Only requirements are that it doesn't break (Street tyres, no drifting), cheaper the better, LSD, 4-stud (don't mind redrilling).
    Here is what I have so far from the forums.
    G
    * unnecessary for strenght and a bit heavy
    * 1370 version is hard to find so most likely needs shortening
    * I think tailshaft needs shortening ?
    * Needs disc conversion (nothing bolt on)
    * Plenty of LSD centers available
    F would be a good choice but
    * needs shortening the housing
    * and the tailshaft aswell
    * Weight and strenght are good
    * Bolt on discs
    volvo also sounds good
    * tailshaft only needs to be redrilled
    * Still needs to shorten the housing
    * cheap LSD centers harder to find
    * Bolt on discs
    * More than strong enough
    * Don't know the weight of it
    All need mounts changed so thats unimportant.
    I guess the most important thing with the three is the total conversion costs (roughly) using all second hand parts and I'll do all the labour except probably the welding. And the only other things are if my points are accurate and the actual weights of these once shortened and with discs. Different posts seems to have some different points so just trying to clarify it all.
    only things I need to know to make the decission are if there are any other costs for conversion (assuming all parts from wreckers are in good working order), the actual weights of the three
    Hello.
    Junior Member Backyard Mechanic rob1's Avatar
    Tas
    What width is an RN25 Hilux diff? Anyone know?
    Quote Originally Posted by rob1
    1365mm same as ra23
    Tas
    thanks mate.
    good luck on finding an rn25 diff, I had to buy a whole car just for one..
    But hey, it'll be strong.
    Facebook | LinkedIn
    If you go for an F series diff from an early Corona MKII (MX13 I think) you don't have to shorten it. All you need do is swap spring platfiorms and trailing link brackets.
  1. How to swap a MA61 diff into your MX73?
    By RA35GT in forum Engine & Driveline Conversions
    Last Post: 01-07-2010, 12:30 AM
  2. T series rear end diff centre change guide (warning, pics!)
    Last Post: 31-05-2007, 12:57 AM
  3. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
  4. XT130 diff ratio swap
    By dale30 in forum Tech and Conversions
    Last Post: 14-02-2006, 10:23 PM
