Results 1 to 15 of 15
Thread: 1jz auto tranny overdrive wiring
    Dec 2008
    Default 1jz auto tranny overdrive wiring
    The wiring in my jzx73 conversion is 99% complete, i just cant figure out how to wire the overdrive button on the shifter.
    anyone know if its switched positive or negative? and where it needs to go to on the jzx100 ECU?
    and at a stretch the same for the PWR and Economy button.
    Thanks in advance.
    May 2010
    Moscow
    Default Re: 1jz auto tranny overdrive wiring
    snow is momentary button negative, input SNWI, bulb output SNWO
    power is positive on/off button, PWR input
    o/d is negative on/off , it must be named "od1" or "odms" on later models its pin renamed to "3" with 4spd auto and "4" with a 5-speed
    Dec 2008
    Exactly what i was after!
    thanks George your a champ!
    May 2010
    Moscow
    cheers, enjoy )
    p/s also, on later models there's no overdrive button, and o/d transmission range is disabled like any other
    so if you see "3" or "4" pin on the ECU diagram, you should supply 12v to the pin to activate the corresponding mode
    and if you see "od1" or "odms" it's supposed to be negative triggered
    Dec 2008
    I don't see od1 or odms on my pin out diagram
    All I have showing on the 28p connector is "2" and "3"
    That's pins 10 and 15 respectively.
    May 2010
    Moscow
    then wire L and 2 to the pattern selector switch on the transmission and "3" to your overdrive button. All of the pins are positive
    Dec 2008
    So wire L on the pattern selector switch to "2" , I'll be splicing into the jzx100 tranmission harness and effectively looping in the signal for this?
    And then OD button to "3"
    May 2010
    Moscow
    not exactly. Look. By moving the classical style pattern selector lever, you can select L-2-D. These are the signals fed into ECU right off the trans-mounted switch.
    When D is selected, by activating pin "3" you turn the o/d off. The pin is activated by a separate button
    Dec 2008
    Right, so the box will, without signal to pin "3", automatically use OD?
    So what does wiring in L, 2 actually achieve? Since the ecu is already getting the selected gear position from the pattern selector.
    And if simply splicing those signals from the selector is not exactly correct, how should I go about this?
    Someone once said to me... ECU's come with built in smoke... Once you take it out, you can't out it back in! Still makes me laugh to this day
    May 2010
    Moscow
    yes it will
    the ecu gets the position only if you wire it. there's no other route L,2,3,R signals could get into ECU pins
    the smoke story is a bit different. In fact, every Jap ECU has some sort of spirit inside. It looks like grey smoke. Once you let the spirit out, the ECU dies
    Dec 2008
    Haha, I like the spirit story better.
    So wiring wise, I've got my dash lights working, park thru to L.
    Is a simple splice into the correct inputs sufficient?
    Administrator Backyard Mechanic
    Jul 2009
    On the jzx100 u push the shifter to the side to take it out of OD. So is it correct to say that what this switch does is give the ecu power on pin 3
    May 2010
    Moscow
    Sure, just splice them between the dash and ECU
    Dec 2008
    You should translate all the important electrical stuff and sell it!
    While I have you, does the jzx100 have a PWR and economy or normal switch?
    And is it switched +ve or -ve
    May 2010
    Moscow
    JZX100 has pwr/economy/snow . Economy is when nothing is activated
    Some JZX100 variants only had PWR/Eco modes
    anyway, PWR is positive as I already told you above
  1. MA61 Auto troubles - No Overdrive
    By demios in forum Tech and Conversions
    Last Post: 13-07-2011, 08:19 PM
  2. SA63 Auto Transmission overdrive problem
    By Farkurnell in forum Tech and Conversions
    Last Post: 17-07-2010, 04:08 PM
  3. overdrive wiring on jzx100 vvti motor
    Last Post: 26-01-2010, 04:23 PM
  4. 5M-E Auto Tranny Issues
    By Trent-KE30 in forum Tech and Conversions
    Last Post: 21-01-2008, 02:40 PM
