Results 16 to 30 of 45
Thread: 1GGTE RA60 Conversion
    Junior Member Backyard Mechanic Dimitri's Avatar
    Default Re: 1GGTE RA60 Conversion
    we make a fitting kit. it doesnt require a custom sway bar like most conversions. but it does require "massaging" of the fire wall.
    if you want search for tims car on the old forums that will give you an idea.
    i think his SN was timottaway, just search ra65 celica drift car.
    Quote Originally Posted by JustCallMeFrank
    The fuel system is a doddle as you can bolt in an entire RA65 EFI setup.
    Why go to that much expense?? RT142 corona tank bolts in, and the fuel lines bend into place with a bit of effort (mind you, new lines are always a good option anyways, as the build up in the lines from previous neglectful owners can be a PITA). How do i know?? I put an RT142 tank in an RA60 when i did a 22RE conversion. Hardest part of changing to EFI was wiring, fuel system was as frank stated, a doddle.
    Depends, a lot of the time an RA65 setup will be no more expensive.
    Maybe its just the ripoffs who have no idea what cars are worth that im used to dealing with. Also an RT142 could probably be picked up as a giveaway, whereas even junk RA65s fetch a few bucks. Mind you you would probably be better off ditching the RA60, get an RA65, and do that up... that way you start with efi tank, and F series IRS diff RA60 has a poo rearend.
    Having bought this would been a good start: http://cgi.ebay.com.au/ws/eBayISAPI....tem=4647943309
    I completly forgot about the auction... *cry*
    TAS
    PM "stefan" off these forums. he has done the conversion in his RA65 (same car basically)
    I'm flattered, but it isn't in yet
    RA60 KID, you didn't find much info??? Did you search??? You have 2 options for fitting the engine:
    * Leave the gearbox in the stock location, make custom mounts & need custom front swaybar.
    * Move the gearbox back a bit, buy mounts kit, massage firewall, shorten driveshaft... and don't need custom front swaybar.
    Either way, you will need EFI fuel tank gear etc, and a front sump.
    TAS
    BTW, Timottoway's GA65 (with option #2, above) is here:
    http://www.toymods.net/forums/showth...highlight=ga65
    Some more 1G rides (into Corona of similar ear, similar conversion)... just my results from a quick search:
    http://www.toymods.net/forums/showth...ighlight=1GGTE
    Jun 2006
    south australia
    Quote Originally Posted by TOSCO
    yea i saw that but i want a twin tubo and besides i can get 1 with full wiring and computer without the gear box for $1500 so i might do that
    Jun 2006
    south australia
    i can get a RA65 tank for about $50 so thats no probs i just gotta get EFI flexi hose for the fuel line and a mate can get me a LSD centre for bout $400 so thats no probs but with those mount kits does anyone know where i can get them from??
    TAS
    If you don't get a gearbox, you will need to get a G-series bellhousing.
    The mount kits are sold by Kaizen Garage. To use these, you have to be prepared to massage the firewall & have the tailshaft shortened.
    Jun 2006
    south australia
    Quote Originally Posted by Stefan
    ok wat do you think i would be bettr off doing with the mounts??
    Jun 2006
    south australia
    do you know how much the mount sets cost and how difficult is it to massage the fire wall and shorten the diff?? not forgetting i want to register this car when im done
    Quote Originally Posted by RA60 KID
    you dont need to shorten the diff, just the tailshaft.
    The diff in the RA60 is a T series, and arent very strong. Brett_Celicacoupe blew his yesterday afternoon after 8 months behind a stock 1GGTE (Gen3)
    Your much better off with the complete RA65, as everything is in place, including a super sturdy F series diff (Norbie has had one behind a 2JZGTE with 400+hp for over 2 years, no probs)
    So yeah, i would be inclined to go with doing up an RA65 with option A, as firewall massaging is going to be a PITA to get through an engineer, mounts are easy, tailshaft is a bolt in, and a spring shop should fix your swaybar problem for minimal outlay.
    Jun 2006
    south australia
    hey
    yea but i really want to do it to my RA60 plus i got a coupe so i want to do sumthing diffrent a RA65 diff should fit in mine though
    hey
    RA65 diff wont just bolt in... its a major job fitting it, you need to modify your rear subframe to fit the diff frame under. They use a different suspension system, different diff mounting etc. Its easier for you to get an RA65 and bolt the front end of your RA60, plus the doors handles and taillights onto it, making it look like your RA60. There was a writeup done by somebody who fitted one of these diffs to an RA40 (identical rear subframe to RA60), and it was certainly not easy... plus its not hard to put the diff in slightly crooked... and if you do that, you can kiss many sets of tyres and a good deal of driveability goodbye. Food for thought.
  1. RA28 stering rack conversion (need advice)
    By bullitt in forum Tech and Conversions
    Last Post: 20-08-2014, 11:37 AM
  2. MA61 - RA65 Struts & Powersteering Arms conversion
    Last Post: 04-06-2013, 10:38 PM
  3. MA70 --> JZA70 Conversion
  4. ST162 Conversion
    By Pure-SX in forum Tech and Conversions
    Last Post: 30-01-2006, 02:34 PM
  5. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
