Page 1 of 3 123 LastLast
Results 1 to 15 of 45
Thread: 1GGTE RA60 Conversion
    Jun 2006
    south australia
    Default 1GGTE RA60 Conversion
    hey guys im just after any help possible on a conversion i am going to do i want to put a 1G-GTE in my RA60 and was just after any info or help u guys could give me on it iv looked through some of the old forums but didnt find to much thnx
    Default Re: 1GGTE RA60 Conversion
    There should be heaps of info around!
    Have a look at Narks webspace, and also Rob_RA40 have guides...
    Junior Member Grease Monkey Intense's Avatar
    check out the old forums too
    Sa22c Series 1 rx7, 12a extend port, 900rwkw @ 93,320 rpm sold
    Ra65 celica hatch, 22re with 2.25" exhaust, 500Nm @ 27rpm sold
    Ae86, 4agze, 170Takumi Powers @ 11,000 rpm
    the old forums doesn't have the old tech articles...
    here's my good deed for the day:
    Nark's web site
    i also have a PDF of Rob's article "RA-23/28/40/60/65 Celica Engine Upgrade" - is a 1.4Mb PDF - PM me if you want a copy.
    [good deed for the day out of the way]
    cheers,
    Charles,
    Jun 2006
    south australia
    yea man that would be great thanx alot anything that will help
    Jun 2006
    south australia
    oh and by the way i want a gen 3
    Gen3 is no different in implementation, just slightly different wiring. You'll still need a front sump regardless.
    Jun 2006
    south australia
    ok what was the hardest thing you found in the conversion? was it the fuel system because i heard that that is the hardest part of the conversion
    im sure NARK will be happy to tell you how he did it. lol, i can still remmeber the updates when he did it.
    he will see this thread sooner or later or PM him, im sure he wont mind.
    The fuel system is a doddle as you can bolt in an entire RA65 EFI setup.
    Jun 2006
    south australia
    ok wat about the engine mounts?
    That is where my memory is hazy and you'll need Nark's info. It matters not whether it's a Gen2 or Gen3 though.
    Jun 2006
    south australia
    ok thnx for the help
    User Conversion King
    NWA
    be wary of reading straight off the RA40/23-1ggte guide as the engine mount/sump setup will be completely different for you. some other things will be different as well.
    PM "stefan" off these forums. he has done the conversion in his RA65 (same car basically)
    hello
    Jun 2006
    south australia
    ok i heard u can get these special mounts that are made especially for these conversions so bassically you can bolt these straight in so the motor will fit with no welding needed
  1. RA28 stering rack conversion (need advice)
    By bullitt in forum Tech and Conversions
    Last Post: 20-08-2014, 11:37 AM
  2. MA61 - RA65 Struts & Powersteering Arms conversion
    Last Post: 04-06-2013, 10:38 PM
  3. MA70 --> JZA70 Conversion
  4. ST162 Conversion
    By Pure-SX in forum Tech and Conversions
    Last Post: 30-01-2006, 02:34 PM
  5. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
