Page 1 of 8 123 ... LastLast
Results 1 to 15 of 109
Thread: 2JZ + GT4/GTR Running Gear Into TA23
    Jan 2014
    west midlands
    Default 2JZ + GT4/GTR Running Gear Into TA23
    hi guys I need help because I do not know how to make a thread . I am intrested in putting a mark1 celica gt4 running gear into my ta23 celica with a 2jz supra engine. I wanted to know what work would I need to do and if the patterns of the bell housings will match to the 2jz from the gt4 running gear hope you can help because ta23 my dream car hope to hear from you all on toymods thanks
    Aug 2013
    Quebec, Canada
    Default Re: few random ta22 q's
    Quote Originally Posted by umar66 View Post
    If you need to ask you're out of your league on that one... sorry.
    Just to elaborate a bit, ST165 to 205 GT4 have transverse mounted engines and gearbox. and 2JZs are straight 6 so it'll never fit between the strut tower, even if the bolt pattern was right or you made an adapter plate, physically it's impossible. If you want to have an AWD TA23 with a 2JZ the only option you have is to go through all the fab that Jaffa went through Link to build thread But with a 2JZ instead of a 1UZ. You could also convert the TA23 to accept the transversly mounted drivetrain from the GT4 (the opposite has been done : mounting a 1UZ longitudinal into an ST185 Link here again but I don't really see the point in doing that...
    And like I said, one thing for sure : you'll never have a 2JZ in front of a GT4 tranny inside a running car, just won't happen.
    KE20 1974 <- Sold -> Thread
    AE95 1990 <- 4A-GZE daily driven wagon...
    Jan 2014
    west midlands
    Default Re: 2JZ + GT4 Running Gear Into TA23
    thanks allot mate I really appreciate your help, I was told that you can use the skyline gtr running gear and hook it up to the 2jz just like Jamie did with a 1uz ?? do you know how much work I would have to do ?? I want my ta23 to be 4 wheel drive but with a 2jz
    Jan 2014
    west midlands
    Default ta23 gtr
    hi guys I need some help , I own a ta23 gt and I want to put a 2jz and a gtr running so the 2jz is four wheel drive. also I i want to convert my car to power steering what rack and things do i need to make it power steering?? hope you guys can help me i really appreciate your help. i live in England and i am only a student at university this is my dream car. i have put a beautiful body kit together and interior just need to sort the mechanical side soon i will start to post the pictures once i start to get the engine and gear box in. so if you could please help me with what i have to do to run my 2jz as a 4 wheel drive either with a gtr running gear or any other running gear that will fit thanks hope to hear from you soon.
    Nov 2011
    if you have a spare 50 grand then you will be able to half finish it
    there is a 1uz that is a 4wd so maybe find that model and maybe use a 1uz
    the sump has the 4wd bits in it
    its probably the cheapest way around it
    also go look at the front strut assembly from a 4wd gtr and you will see what you are trying to do is
    stick a 20 inch round circle into a 4 inch square
    Melbourne, Victoria
    So what exactly is your ultimate aim for this car?....(drag car / track car / daily driver).....your proposed build would probably be good for the drag strip but not much else. The weight and physical size of these components would only lend itself to straight line speed in a TA23.
    I could go on but unless you have significant mechanical knowledge, a large disposable bank balance and access to a wide variety of machine shops and engineers to assist then you should just go buy a Nissans Skyline GTR if you want a turbo straight 6 4wd.
    - Jackie Stewart
    I'd suggest you send Jamie a PM to get an idea of the amount of work (and knowledge, and time, and money) that went into his project, then work out whether you might be stretching a little bit too far.
    You'd really only do this if you wanted something unique & special, and time & money weren't really an issue. Even with a lot of smarts and the knowledge to do most of the work yourself, this will still be an EXPENSIVE project. If most of the work is out of your league (like it would be for the vast majority of people) it'll be a very, very expensive project.
    Otherwise, as suggested, just buy an r32-r34 GTR - you could buy any of them cheaper than this project.
    Administrator Domestic Engineer mynameisrodney's Avatar
    Default Re: 2JZ + GT4/GTR Running Gear Into TA23
    I have merged the two threads into one.
    Umar, when having discussions like this in the future can you please keep it to one thread. Cross posting in many threads pisses people off as it clutters up the forums. It also makes it difficult for people to follow your progress later on as they have to chop and change between many threads.
    Everyone else, please keep it civil. If you have constructive criticism by all means air it. If you're just going to crap on about how students cant do shit I suggest you read this thread instead of posting here.
    Chris
    Aug 2009
    there is 1jzge 4wd jzx100 mkii's and chaser's that gearbox ect which will be an option for bolt on 4wd gear for 2jz
    Jan 2014
    west midlands
    thanka allot guys i really appreciate your help and silly rabbit i want to use it as a everday car, i understand theres allot of work involved , i spoke to sajid Mughal from jap performance parts and he said that this would be a waist of time he said if i was to make it four wheel drive i should use a Subaru impretza engine and running gear so i am not sure atm, im thinking of just restoring my ta23 gt with the original engine with the body modifications such as my bodykit and alloy wheels and leaving the mechanical side original for nw. i think i will do some research and put something together. money isn't the issue i just want to make something different and special, because of my disability i need power steering do you guys know of any power steerings that will fit my celica?? Rodney im really sorry its just that i am first time user of this website and i am bit confused. sorry it wont happen again but once again thanks to all you guys really appreciate your comments and help
    Not a problem, everyone was new here at one point.
    If it's a genuine GT, then I wouldn't hack it, you will drop it's value. If you want to go the modification route, you are better off selling the GT, buying an LT, and using the left over money to go towards the mods. Otherwise look at restoring the GT in original style.
    Chris
    Junior Member Backyard Mechanic slipway's Avatar
    brisbane
    i doubt s subbie motor would fit,there wide in the wrong spot.
    just for reference 2jz cut and shut to gtr box
    Jan 2014
    west midlands
    yhh Chris its a genuine gt but value doesn't bother me because I will never sell it. I just want to do something different I want all the original gt interior and everything except I am adding a front spoiler side skirts boot spoiler and a rear spoiler that fits under the chrome bumper and I am having my whole quarter and wing cut and flared out i.e welding, iv ordered 17 inch deep dish wheels from image. I am going to build a one off piece I can guarantee you that. thanks allot slip way I will look into that . Chris what's really disappointed me is the increase in value of these cars its crazy my dad said when he was my age he used to buy them for like 500 to 800 pounds. guys has any one got a rear louver for the ta23 celica???
    Jan 2014
    west midlands
    slipway do you know what work they did to get the 2jz hooked to the gtr running gear??
    Now that's the go slipway!
    Umar66 that unholy marriage would be the result of handing the GTR gearbox & a JZ bell housing to a machine shop - or being a machinist oneself! Much better than subie gear if you are deadset on such a swap.
    Jason
  1. T-18 running gear into TA22??
    By walt in forum Tech and Conversions
    Last Post: 19-01-2008, 12:51 AM
  2. TA23 running gear into TA22
    By Stephen1974TA22 in forum Tech and Conversions
    Last Post: 16-01-2007, 02:27 AM
  3. 4wd running gear bolts into na 5th gen ?
    By Tarkers in forum Tech and Conversions
    Last Post: 24-02-2006, 10:59 AM
