I just googled the fault today & the stuff I found seemed to be faulty oil pump relief valve housings with Some New pumps but that was some years ago ( had hairline cracks in the housings ) & the oil pump drain hole seemed only really relevant with old Worn oil pumps building up pressure behind the seal, but you said your pump was New so I wouldn't think the Drain to be a big issue in your case otherwise all pumps Replaced should leak ? unless the drain was modded which I can't see many people doing ....
