I picked up some notes from the process of trying to start it yesterday and noticed a few things
- Wire getting hot as I may have left a bolt somewhere in the dash off which the wire passes current though.
- Battery low causing not enough energy to start the car
- Accelerator Cable wasn't connected so we might not have had enough air coming in. We had also removed the stop screw for the throttle body so these 2 factors may have not worked so well together.
- Dizzy Timing could have well been out causing the spark to not fire at the right time.
I was going to do the timing belt/water pump tonight since the water pump is leaking from the weep hole.
