Yes the 7M-GE Knock sensors are the same as 1G-GTE.
A few thing you can look out for once you have fitted your new sensor
When the motor runs above 2200RPM error code 52 will be reported if the sensors are not working and engine will go into limp mode.
When the sensors detect a ping event the factory ECU retards the timing up to 15 degrees and this is held some time after the ping event.
