Results 1 to 15 of 27
Thread: mx83 cressida - vvti 1j swap
    Junior Member 1st year Apprentice KAMAKAZ's Avatar
    May 2009
    wa
    Default mx83 cressida - vvti 1j swap
    hey everyone joined up a lil while ago to try find some info on the swap i plan on doing but cant seem to find what im looking for
    i will be using a jzx100 auto half cut into a 1992 mx83
    i have been told the motor its self bolts straight in, but not sure about the tail shaft and the wiring side of things
    also is the exhaust manifold on the vvti motor different to the non vvti 1j planning on doing turbo swap before the motor goes in
    will the 1j tail shaft fit?
    gear box cross member?
    i know this conversion has been done a few times before but nothing i could find has been wirtten up about it
    just wanted a better idea on things before i started to attempt it
    thankyou
    Ben
    Junior Member Grease Monkey twiztd's Avatar
    Aug 2006
    Default Re: mx83 cressida - vvti 1j swap
    hey ben, try hitting up the cressida forums, hit search and you shall have *most* of the answers you need... http://forums.toyotacressida.net/forums/
    - vvti and non-vvti manifolds are different i believe
    - tailshaft depends on what gearbox you're using, same as gearbox crossmember
    - should be able to find all wiring details on jzx100 forums or cressida forums
    Mike
    Now - 1988 GX81 Mark II- 7MGTE, GT35R, TiAL 44m, Microtech, 550cc injectors, R154, Xtreme clutch, LSD.... Low boost tune done = 330rwhp@1 BAR...
    Then - 1989 MX83 - The big scrap heap in the sky...
    May 2009
    wa
    i cant sign up there as i have a hot mail address all it shows is like lawn bowls n random topics like that
    OneJayZee Grease Monkey bungs's Avatar
    Quote Originally Posted by KAMAKAZ
    lolz
    Yea you might wanna try and get a proper email address to get all the info you're looking for. Nobody's gonna spoon feed it here
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    You'll need some jzx81 or jzx90 engine brackets.
    Put the 7mge rear extension housing and speedo gear onto the jzx100 auto. Tailshaft and transmission mount will bolt straight back in.
    If you get yourself a halfcut that will have alot of the bit's you'll need for the conversion. ie: acc cable, power steering canister/line, hoses, etc.
    I can do the wiring for you. I'v wired up about eight 1jz cressys and another three 2jz cressy's.
    PM me for more info and help.
    1994 GZX90 Mark II 1GZ-FE V12
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    1jz vvti and non vvt heads are different so manifolds are not interchangable
    May 2009
    wa
    ok will get a new account somewhere and check it out ha ha
    cheers triptek will be in touch for some of the wiring, does it have any problems with standard turbo clearence?
    Ben
    May 2009
    wa
    also whats a good turbo upgrade, while the motors out may as well do something, get the stock one hi flowed? or just go aftermarket, is there many bolt on options for this or all pretty much top mount only
    thankyou
    Ben
    HKS do a few kits for the vvti, but there way over priced. I'v heard good things about hiflowing the stock turbo. This is what i'm planning on doin with my vvti turbo.
    Junior Member Grease Monkey seamonsta's Avatar
    May 2007
    Hills Area Sydney
    PeterH on these forums has a manual one he did himself, he can probably offer some advice as well, FYI.
    Tim
    Feb 2008
    victoria
    sp2 runs the trans on these things-mine wouldn't shift out of 1st without it anyways,and yes i did try to run it of sp1 to no avail ,also note the reluctor ring is 12ppr and is shorter than std 4ppr-the 12ppr is held in place with clip-you will see the groove. im nearly 99% sure there is no sp1 on trans shaft(can;t remember but in my little bucket of i should keep parts-no sp1 trans sensor).with mine i used the cressida extension housing, jzx100 pulse ring,10mm spacer (cut from my old alloy mx83 1 pulse ring) and my mx83 spedo ring.
    i had to mod the extension housing to accept sensor.
    old cressida sp2 sensor with about 20mm cut off tip used to plug sp2 sensor hole,
    have fun
    May 2009
    wa
    didnt really understand that bro whast sp2 and sp1?
    Feb 2008
    victoria
    sp1 and sp2 are vehicle speed sensors in the auto trans gear box, the ecu needs these to correctly operate the transmission
    May 2009
    wa
    oh ok cheers for that mate
    Mobile Backyard Mechanic PeteH's Avatar
    May 2007
    Quote Originally Posted by seamonsta
    Tim
    Geez I was trying to keep my head down on this one, thanks mate
    While I did do the conversion myself the single job I did farm out was the wiring. I have a fairly basic understanding of auto electrics and thought I'd be better of paying someone rather than fight with something I'm not comfortable with.
    Having said that if there is anything specific you'd like to know just shoot me a PM and I'll see if I can help....
    Pete
  1. 1990 mx83 Toyota Cressida Manual conversion
    By 01jzcressy in forum Tech and Conversions
    Last Post: 27-07-2008, 11:51 AM
