Results 31 to 45 of 61
Thread: KE70 - A Gas Guzzler
    Default Re: KE70 - A Gas Guzzler
    just for reference, my MA70 Supra uses around 18-20 Litres per hundred!
    Eldar.O.
    dude there's something wrong with your ride... 20 litres to 100 kms is worse than a race built pushrod V8 with 2 speed at dragday. Was a VK, and 5 runs + some cruising returned 300 kms to 50 litres.. (16 litres per 100 kms) and is a 12 second 1/4 ride.
    2NZ-FE is gold for economy no matter how u trash it it still goes hard and won't drink petrol like beer.
    Junior Member Grease Monkey Raceflo's Avatar
    To clarify the comment, if I am driving the KE70 and I drive it fairly hard, it returns between 450 and 550 km per tank, if my wife is driving to and from work she regularly returns between 600 and 700 km per tank, and yes the trip meter is always reset, and the car is only run on BP ultimate.
    Jon
    Always look on the bright side of life
    Selangor
    Quote Originally Posted by GtiRboy
    one very noob question here, im nto that mechanicall minded, like know basic stuff etc, but how the fark do i advance/check/change my timing? i've never done it before and i suppose i'll get neg repped for asking or whatever, but most things i read say "use a timing light" or some shit but i wouldnt know where the fark to use it lol..
    please, no neg rep
    If you do not have a timing light, you can
    try static timing as I sometimes do. But this
    can only be used if you have contact points,
    not electronic ignition.
    You will need to have a multimeter though.
    An analog meter is better, as a digital one
    is a bit hard to read in such an application.
    Set it to "X1 resistance".
    1. Take off the distributor cap. Start-crank the
    engine briefly until the rotor points almost
    towards the No. 1 plug wire. Note that the
    rotor swings clockwise. If you overshoot,
    just crank again. If the rotor is already near
    the No. 1 plug, then skip this step.
    2. Look down at the crankshaft pulley. You will
    likely see the timing notch just to the left of
    the timing marks (marked "0-20"). Turn the fan
    manually until the notch aligns with the timing
    you desire. Try 15 degrees first. You can also
    use a 19 mm wrench to turn the crankshaft pulley.
    3. Now loosen the distributor's locknut. You need
    someone else to tap the multimeter's leads, one
    to the ignition coil's negative terminal, and the
    other to any good earth. If you have two crocodile
    clipwires, then you don't need a friend to help you,
    just clip each wire to the end of each lead and the
    coil negative/earth.
    4. Set the meter to "X1" resistance. Most likely, the
    meter pointer will swing fully right to "0" ohms,
    indicating the points are still closed (and your
    original timing is less than 15 degrees). Now loosen
    the distributor's locknut. Turn its body very slowly
    anticlockwise (to advance the timing) until the meter
    just swings left, which means that the points are
    opening and you have reached your desired timing
    advance. You may need to turn the distributor body
    to and fro a few times to fine-tune its position. The
    contact points distributor also usually has a plastic
    knob at the rear of the vacuum diaphragm, which you
    can turn for fine timing adjustments. It is marked "A"
    for advance and "R" for retard. Then lock the nut.
    5. If, in the above step, the meter did not swing right
    initially and stays left, this means that the points
    have already opened and your original timing was
    more than 15 degrees. Then you will have to turn
    your distributor clockwise instead to retard the
    timing, until the points close back and the meter
    swings right.
    If you do not have a multimeter, use any 12 volt bulb.
    Solder two wires with crocodile clips at the other end
    to each terminal of the bulb. Clip one end to the coil's
    positive terminal, and the other to the coil negative,
    or its terminal on the distributor. Switch on your key
    to the "Run" or "Ignition" position (the warning lights
    on the dashboard will light up). Repeat Step 4. If the
    bulb lights up, it means the points are closed. Turn
    the distributor anticlockwise until the light goes off,
    which means that the points are open. If the bulb is
    not lit initially, the points are already open, and you
    turn clockwise to light the bulb and close the points.
    Then turn off the ignition. Note that you must work
    fast if you use this method, or else the coil may
    overheat with the ignition turned on too long.
    Alternatively, with this method, you can set the
    multimeter to read voltage instead of a light bulb.
    wow thats right, there was life before electronic ignition
    it seems a timing light makes things much simpler..
    yea it took me a while to see where the notch meets up with the marks to tell how many degrees of timing it's at... but it's worth it... i can't see those visual puzzles for shit but this is much easier once u get the hang of it.
    maybe someone could enlighten Tham what to see using a timing light? all i can say it the notches on the crank and the fact the light blinks when the marks match up and point toward the notches (0 - 10 -15-25 or something like that)
    Selangor
    Thanks, Vios GT. I already know how to use a
    timing light, very straightforward. Just telling
    Gti Boy how to do static timing if he did not
    have a light.
    I had one from the 80's to 90's and used it on
    my Isuzu Gemini and Mitsubishi Cordia.
    But it's long broken down and I had resorted
    to static timing for my KE70 when it had points.
    Accuracy is not that bad, probably within +/-
    3 degrees.
    I've recently switched over to an electronic
    distributor however, so I'll have to get a new
    timing light sometime.
    timng lights are cool. kinda like a strobe light, only useful ahahaa
    anywho, did the timing on the ke70 today, was dead on the toyota spec 8 as i set it a year ago,wound it forward to 20 and took her for a run, went well, and seemed ok, just idling at 1500, so played with the carb, and in the engine bay you could here it knocking as you shut the throttle off and it returned to idle.
    so i set the tappets, and wound the timing back to 15, seems better and isnt knocking, didnt get the chance to take her for a run tho. have to wait and see how she goes economy wise
    p.s. this is on ULP, none of these premium mumbo jumbo for my old girl
  8. #38
    Western Aus
    sucky fuel economy on BP Ultimate sucks teh wang!
    20 litres/100k's is 10-11 psi, daily, city driven
    Eldar.O.
  9. #39
    get lighter shoes
    or a pushbike
  10. #40
    Selangor
    yar, the aisan carbs are not so great..
    Yes, I've always thought about converting
    to a Nikki or Hitachi.
    The Aisan's crappy idle is indicative of design
    errors in the air-fuel mixture circuit and results in
    improperly combusted fuel emitting in the exhaust.
    Wished Nikki made direct replacements for the
    4K - they're very economical and relatively reliable
    carburettors, apart from a flooding bug.
    I had an Opel (Isuzu) Gemini from 1983 to 1993, with
    a Nikki. It idled really smoothly and steadily right up
    to when I sold it, unlike the Aisan. It did overflow once
    or twice though - I've heard this is a problem with
    some Nikkis, particularly the one on the Datsun 180K
    (L18 engine) in Malaysia during the 80's.
    The Gemini's air filter also had a hot idle compensator
    bimetallic strip built in, so one was not needed on
    the carb, unlike that on the 4K's stock Aisan. All you
    needed was a hose to connect it to the intake manifold.
    I found this link, but received no response from them.
    http://www.carbs.freeuk.com/nikki_carburetters.htm
  11. #41
    Western Aus
    get lighter shoes
    or a pushbike
    had a pushbike, well, ive had around 6 or 7...
    after the last one got stolen, that, along with the two before it being stolen too, kinda makes me not want to own another one
    lighter shoes? i drive barefoot sometimes...
    i cant help it, i love being pushed back into my seat by the neverending torque all the way up until redline, that said, im not complaining, if thats what it costs, so be it
    Eldar.O.
  12. #42
    Is not a good Backyard Mechanic GtiRboy's Avatar
    N.S.W
    LOL ^^^
    Well anyway people, i know i sort of ripped off thams thread but thankyou to everyone who helped with the timing thing.
    Anyone know of any books or publications that help with the tuning of a KE70 4K-C or a carby engine etc?
    Mmmmmmmm 2ZZGE
  13. #43
    NT
    My Ke70 gets about 10L/100k seemingly nomatter how I drive it... either hard or granny and it gets pretty much the same. Occasionally it'll go 9L/100K. On regular 91 octane too.
    Timing is pretty normal I believe, how much could it be advanced on 91octane? Or knocking doesn't hurt these engines too much so just experiment?
    Western Aus
    knocking doesnt hurt these engines for half a shit, go for your life!
    id thoroughly suggest running 98 though!
    Eldar.O.
  15. #45
    Eldar.O.
    ahem...
    knocking KILLS the rings and ringlands... ESPECIALLY for the later 3K and 4K motors with the repco/toyota pistons. they seem to be very fragile, and i've seen a few motors pulled down now.. only blowing a little smoke, with no rings or ringlands intact.
    DON'T advance timing until it pings.... unless you want to rebuild.
    91 octane is crap and no car should run on it 95-98 ftw. only advance timing as much as creates more power everywhere. any more is costing you fuel as the engines fights itself.
  1. KE70 Panel Van Dash
    By Gleno28 in forum Tech and Conversions
    Last Post: 23-04-2010, 01:21 PM
  2. Ke70 4age
    By merc-blue in forum Tech and Conversions
    Last Post: 09-09-2006, 02:32 AM
  3. KE70 panels
    By poorolla in forum Tech and Conversions
    Last Post: 28-05-2006, 09:12 AM
  4. t18 diff in ke70 handbrake cables
    By spoon in forum Tech and Conversions
    Last Post: 14-12-2005, 09:11 PM
