Results 1 to 6 of 6
Thread: 4agze misfiring under light load
    Default 4agze misfiring under light load
    Hi everyone,
    My 4agze in the ae86 recently start to misfire, but only under light load e.g cruising along at 80kph 2500rpm when I gradually press the throttle to go a bit faster you can feel the engine stumble a bit around 3-3.5krpm. Doesn't happend if I just floored it or press the throttle hard. The car still making good power drives fine just pop and stumble around the 3000-3500rpm range. You can also hear the misfire if you gradually rev the engine at idle .
    So far I've changed the spark plugs, ignition leads, coil packs, new O2 sensor and had the injectors sonic cleaned. After all that the problem is still there. Not sure what to do next any suggestions?
    Thanks
    Tom
    JZZ20 Backyard Mechanic forey's Avatar
    TAS
    Default Re: 4agze misfiring under light load
    Put a multimeter on your tps signal and ground wires to make sure it has correct voltage
    If not then adjust it, between 0.6v and 0.7v at idle as far as i know
    If i has an airflow meter carefully clean that out too
    87' z20 Soarer - 1jz Gt35r -
    RAAFENG Domestic Engineer punkture's Avatar
    Apr 2008
    Map or afm?
    Current: 1990 ST185R Celica:
    http://www.toymods.org.au/forums/showthread.php?t=62315, DAEWOOOOO ESPERO
    Previous: Ta22 4aGZE; Older: 99' WRX Impreza 192kw
    May 2012
    Good start with the basics taken care off...
    Second that on the AFM...
    MAP sensor 4agze from AE92 Levin.
    Junior Member Conversion King
    May 2010
    Check your MAP sensor.
    There's been quite a few similar issues pop up on this forum recently, exactly the same kind of issue with a misfire on light throttle but not so bad at WOT, also occasionally bad idle. MAP sensor replaced and all was well.
  1. 4agze engine problem - hesitates under load...
    By mookschank in forum Tech and Conversions
    Last Post: 09-07-2010, 05:40 PM
  2. aluminium vs chromoly light flywheel 4agze
    By stepan117 in forum Tech and Conversions
    Last Post: 25-05-2010, 08:07 AM
  3. Inductive timing light wont work on my 4agze
    By Necros in forum Tech and Conversions
    Last Post: 21-02-2007, 06:59 PM
  4. Replies: 20
    Last Post: 24-01-2007, 12:01 AM
  5. 4agze missing under load
    By rollamattae86 in forum Tech and Conversions
    Last Post: 18-04-2006, 03:04 PM
