Results 16 to 18 of 18
Thread: setting the timing 1jz? new gears, cams, belt
    Junior Member Grease Monkey BEVANI's Avatar
    Apr 2008
    Default Re: setting the timing 1jz? new gears, cams, belt
    looks pretty close to the same as what mine is. nice job!
    If in doubt, drift her out! Steer from the rear! less traction,more action! simple!
    BURN RUBBER
    ░░▒▒▒▓████ JZA61 FTW!
    May 2012
    thanks for the help man!
    Nov 2007
    Mine was much closer than that, perhaps after a couple of turns of the Crank and it will line up more Truly. Normally if one tooth is closer to the backing plate mark than the other, then that tooth is the one that is the corresponding one. They won't always be 100% Truly Inline, but you'll get the idea if it is closer than any of the other ones on there.
  1. Setting ignition timing
    By thu187 in forum Tech and Conversions
    Last Post: 27-02-2010, 10:00 PM
  2. setting lash on cams.. can i get away with a few being loose?
    By Dimitri in forum Tech and Conversions
    Last Post: 19-02-2009, 04:33 PM
  3. Replies: 25
    Last Post: 02-10-2007, 08:04 PM
  4. Crank timing pulley timing belt guide, fixed or spinning?
    By Howieau in forum Tech and Conversions
    Last Post: 27-09-2007, 06:06 PM
