Results 1 to 15 of 18
Thread: setting the timing 1jz? new gears, cams, belt
    May 2012
    Default setting the timing 1jz? new gears, cams, belt
    hay there just rebuilt my motor and im now trying to install the cams gears and timing belt. now im not sure how to find tdc for the camshafts (cam gears tomei , shafts are brian crower). any hints
    May 2012
    Default Re: setting the timing 1jz? new gears, cams, belt
    ive done some reasearch now from what ive seen the dot on the gears have to allign in the middle is that correct like pictured
    Junior Member Grease Monkey BEVANI's Avatar
    Apr 2008
    ill be honest with ya my timing marks on my cam gears are at the top (both upright)
    the backing plate on the cams have marks on them that the cams are ment to line up with
    in the case of your cams the dots may be what are ment to line up with the timing marks on the rear cam cover but dont quote me on that
    i always thought the white mark on the tooth part of the gear was what you line up with the timing marks
    If in doubt, drift her out! Steer from the rear! less traction,more action! simple!
    BURN RUBBER
    ░░▒▒▒▓████ JZA61 FTW!
    May 2012
    ok but what would the point of the black dots on the gear be? i thought that line was so u can retard/advance the cam
    Apr 2008
    this is true but the factory cams also have a line that runs identical to the white line on the cams
    better yet do you have a original set of cam gears ?
    they will only go on one way to the cam and the timing mark points straight up..
    BURN RUBBER
    May 2012
    nah there at the dump. this is a real pain in the ass.
    ok so i need to know exactly the order you do things here because i cant seem to get it right , its hard to get the cams to sit exactly right cause of the big lobes the exhaust cam sits a to high at the back for me to put a cap on. i cant seem to get the hks timing belt on the gears as it is tight as all fu$k. any hints
    Apr 2008
    you should be instaling the cams into place prior to any belt install.
    take all your caps off and sit the cam/s in the right spot and spin the cam around until it sits as close to level as possible in the head, sit your caps in place and drop in your bolts. they should be done up the same way you would tension the head to the block so not to damage the bearings
    with all this in mind is prob best if you have engine @TDC
    on a STD cam gear the centre hole has a small cutout for the locating pin that holds it to the cam.
    the timing mark is dead inline with the the locating pin
    so if the aftermarket cams are built the same then the locating pin on the front of the cam should be at the top and the cam gears should then line up giving you an idea if its the dot on the cam or the actual line on the front of the cam
    ill go take some pics for ya
    BURN RUBBER
    Apr 2008
    this pic you can see the timing marks on the rear cam cover, cam and on the belt
    also the locating pin on the middle of the cam
    BURN RUBBER
    Apr 2008
    BURN RUBBER
    May 2012
    yep thats correct. i have the locating pin in my cam gears. now everytime i do up the caps the fuckin cam turns a few teeth every time ahh ready to coffee table the pos
    Apr 2008
    they will move when you first clamp them down but once they are clamped down you should be able to turn them with a socket on the bolt to line them up
    just no big movements coz once clamped you will be moving valves also
    BURN RUBBER
    May 2012
    yeah this is a learning curve and a half. just ashame if i took it to a shop they would want 2k probably
    just to look at it
    May 2012
    yeah what!
    Uploaded with ImageShack.us
    Apr 2008
    NICE! you got it all together, looks the goods!
    so is the timing correct?
    BURN RUBBER
    May 2012
    i think so its as good as i could get it will it be good enough u think? its really hard to get it to all line up and get the belt on at the same time
  1. Setting ignition timing
    By thu187 in forum Tech and Conversions
    Last Post: 27-02-2010, 10:00 PM
  2. setting lash on cams.. can i get away with a few being loose?
    By Dimitri in forum Tech and Conversions
    Last Post: 19-02-2009, 04:33 PM
  3. Replies: 25
    Last Post: 02-10-2007, 08:04 PM
  4. Crank timing pulley timing belt guide, fixed or spinning?
    By Howieau in forum Tech and Conversions
    Last Post: 27-09-2007, 06:06 PM
