Results 1 to 12 of 12
Thread: Automatic not selecting overdrive :(
    Feb 2010
    Default Automatic not selecting overdrive :(
    I have had this problem with my auto for a long time now and it's finally pushed me over the edge -_- my auto will not select overdrive except for the rare occasion. I believe it's the auto from a Soarer to fit my 1jz, but previous to the swap I was still having the same drama. Because of this I am thinking the mechanic didn't actually swap the box at all. The diff in it is also real noisy, not sure if that can cause any issues. If anyone knows this problem please help!
    Nov 2011
    Default Re: Automatic not selecting overdrive :(
    no overdrive normally means wiring problem or ecu
    overdrive works when no power gets to the solenoids in the box
    Junior Member Conversion King
    May 2010
    Transmission fluid not getting up to temperature perhaps? If it's sometimes selecting but other times not, then usually indicative of a problem in your cooling system.
    Also solenoid may be on it's way out.
    Nov 2011
    there is no solenoid to trigger over drive on a 1j box
    solenoids control 1st 2nd and 3rd then when they turn off u get overdrive
    not sure if this is a conversion but maybe overdirve switch aint wired up
    also some boxes have a temp sensor so u might be right in oil temp as if ecu
    is reading oil temp is cold all the time then it might stay out off overdrive
    Feb 2010
    Well I took it to an auto place and apparently no speed sensor or any sensor for that matter is plugged up -_-
    Duct Tape Solves All Conversion King ivandude's Avatar
    Jan 2010
    Also if youre wanting to treat the auto well , seeing as you are diagnosing it and fixing it up , give it a separate transmission cooler will improve the life of your auto a lot, and only costs like $100 for a kit to fit one.
    1982 Soarer MZ11 1JZ-GE VVTi build
    1981-1985 Z10 Soarer Owners International Group
    Former rides ~~ RA65 '85 Celica ~ MA61 '84 Supra ~ JZA80 '98 Aerotop ~ AE101 '92 Levin Toyo4life
    Feb 2010
    Quote Originally Posted by ivandude View Post
    Already has one, fuck it... Bought a manual box and going manual. This will fix my problem
    Nov 2007
    Check that all Water Temperature sensors on the Engine are working to spec, some ECU's may rely on the water temp as an indication of how long it has been since the engine was started.
    Nov 2011
    This is a common problem and what happens is to put it simply the ECU has died or is dying. The capacitors in it reach the end of their useful life. leak and then degrade the tracks on the motherboard. Then what happens is you loose overdrive/lock up, then get slow/rough shifting and a power loss from the engine. Solenoid gone in the auto you tend to loose first gear and the only way to confirm that diagnosos is as set out in the factory manual is to manually shift it from 1st to see if all the gears are there up to 3rd
    His. 2005 GRJ120 Prado VX
    Feb 2010
    Quote Originally Posted by 4th surf View Post
    Well, when I put it in 1st it seems normal but as you get to like 20km/h over it will slip into second. then as you slow down it will harshly drop into first.
    May 2010
    Does the transmission have a control cable, or possibly relies on the throttle cable/TPS, or even both.
    On mine if you didn't have the control cable or throttle properly adjusted, it gives you harsh shifts and occasional slip before disengaging/shifting. Also sometimes shudder on takeoff in 1st.
    BGB showed the proper way to ensure it was adjusted.
    Nov 2007
    Transmission ECU Relies on Speed and Throttle Position Mainly.
    Capacitor Problems is common mostly in JZA70 1JZ and Early 1UZ.
  1. MV box not selecting all 4 gears
    By Mr DOHC in forum Tech and Conversions
    Last Post: 06-02-2008, 01:34 PM
  2. Selecting a compression ratio for a 20V
    Last Post: 05-07-2006, 11:09 PM
  3. Selecting the right turbocharger
    Last Post: 01-05-2006, 02:30 PM
