Results 1 to 5 of 5
Thread: LEXAN Window Sheet
    Mar 2010
    Default LEXAN Window Sheet
    Hi Guys, does anyone knows where can i get hold of Lexan GE window sheet here in Brissie? also, what thickness specs best for drag car. any info would be great...Thanks
    Jun 2007
    Default Re: LEXAN Window Sheet
    Try anywhere that makes windows for houses. We used Marguard windows in forestry equipment when i drove a harvester and we just bought sheets from a window supplier and cut them to size with a jigsaw. Anywhere that sells large machinery should be able to get it for you too. It is slow going trying to cut the stuff. You have to cut at a slow speed with water running over it to stop it melting and ruining your blade.
    I would check the cams regulations regarding thickness. At a guess i would say 5mm would do.
    May 2007
    need to check andra specs rather than cams
    SPARCO|TEIN|SUPERPRO|SELBYS SWAY BARS|PERFORMANCE PARTS AND APPAREL LIKE US ON FACEBOOK!
    Jun 2007
    Oops yeah meant to say check ANDRA regulations for thickness if you are running 1/4 mile. I think some 1/8 mile tracks are CAMS rules sometimes depending on what class you run.
    Jun 2008
    Why stop with just a window? Put the following link into your web browser:
    The Incredible 1939 Pontiac Plexiglass Ghost Car [21 pics] «TwistedSifter
  1. Where to get a bit of aluminium sheet?
    By TERRA Operative in forum Tech and Conversions
    Last Post: 27-07-2009, 09:20 PM
  2. 1G-GTE Bearing size grading sheet??
    By Karma Supra in forum Tech and Conversions
    Last Post: 08-06-2006, 10:19 AM
  3. Dyno sheet from GZE tuning
    By mullett in forum Tech and Conversions
    Last Post: 11-04-2006, 09:21 AM
