Results 1 to 15 of 27
Thread: Dyno sheet from GZE tuning
    Default Dyno sheet from GZE tuning
    Finally worked out the transfer of the pic, this is the before/after dyno runs after an hour of tuning on a JayCar fuel/air adjuster. The mods are:
    4A-GZE (AFM)
    Cusco Extractors
    2.5 exhaust
    GTi-R cooler
    165mm pulley
    Fuel Air adjuster
    The ECU was an 89 G-Limited model.
    RM.
    Note that this wasn't a shootout dyno, add about 10hp for shootout (I think)
    south australia
    Default Re: Dyno sheet from GZE tuning
    about what PSI is that 165mm pulley running?
    ive got:
    175mm pulley
    mircotech lt10s
    large frontmount
    bigger injectors and fuel regulator
    4-1 extractors and 2.5 inch system
    RWD inlet manifold
    holden 5.0 LT throttle body
    havent put engine back in car yet....im quite interested by other peoples figures and im wondering what mine will make....???
    its in an AE86, by the way
    wa
    Did you add the extractors at the same time as the exhaust? Do you know if it helps much? I read that the AGZE factory ones where fairly decent.. what do you think?
    I scored: These came with my car from J The factory headers can't be too bad, but I imagine they're reaching their limits when you start pushing extra power thru them. The 165mm pulley is making a regular 10psi, personally I think this is all you should push thru an SC12, or you're just pushing heat. SC14 coming soooon....
    RM.
    perth
    my setup on the ae82 was
    microtech ltx8
    175mm pully
    headwork and modded inlet manifold
    big frontmount
    standard exhaust manifold
    and on 10/12 psi i cracked 160hp
    but i can only find this dyno but it will do.
    Robots! dancing robots! Domestic Engineer gearb0x's Avatar
    is that on a aw11 or ae92/101 bottom end?
    My dead stock Aw11 GZE turned 80kw at the treads if anyones interested (well, its got some crap rusted out HKS cat back exhaust thing but u dont count that as a mod )
    AW11. It made 129 on a shootout dyno before the cooler/tuning/pulley, so I imagine it's now making 140 or so shootout HP. Next on my goodies list is aftermarket managment and an SC14...
    RM.
    Interesting difference here. My MAP AE92 engine (8.9:1CR, smaller SC pulley) made 147hp at the treads on a 164 mm HKS pulley. Thats around 12psi or so. Through a 600x300x75 cooler and bigport 240* cams.
    Ill find the dyno sheet soon.
    There is no blanket rule to how much to add for a Shootout mode. That jump in the AFR's could be the source of some of the problems you're having in regards to smoothness.
    Yeah, absolutely, that was just a rough guess to compare to a shootout. Next time Hyperdrive have a dyno day I'll take it down. Mainly I wanted to show the difference a little bit of fuel tuning could make.... A programmable ECU is the way to go, for sure. Just out of curiosity, will a low-end ECU such as a microtech give worse economy in standard driving than the factory maps? If anyone knows...
    Quote Originally Posted by mullett
    depending on how the tuner sets it up. if your cruise maps are set right, you should return similiar economy to standard, and sometimes better / worse depending on what AFR's the tuner has set it to. Microtechs perform well and will make the power where it should, but due to fairly coarse resolution, overall economy can be less than that of say a Haltech or Autronic.... But like you said, "for a lower end ecu" they are good value for money.
    My stock Mr2 was running 10:1 AFRs almost across the board on the dyno so its not gonna be hard to improve on the stock economy
    Ill have a better idea of what AFRs it runs at when i get the wideband controller installed i just finished building
    perth
    gearbox its a ae92 8:1 comp engine
    AE92s are 8.9:1 apart from a very miniscule few which were dizzy driven 8.1:1s. Might want to confirm that.
    Minor detail, but they were dli not dizzy and of course had afm. Ive seen a few (92 afm's) around the place.
  1. *** Dyno Day History Lesson ***
    Last Post: 09-04-2013, 08:50 AM
  2. back on dyno with 50mm quads
    By Celica RA45 in forum Tech and Conversions
    Last Post: 30-01-2006, 07:12 AM
  3. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 10:46 PM
