Results 1 to 15 of 27
Thread: Oil Filter/cooler Sandwich plate with Thermostat In-Built
    Jul 2008
    Auckland
    Default Oil Filter/cooler Sandwich plate with Thermostat In-Built
    MRP Oil Filter Thermostatic Sandwich plate
    Sick of buying those oil cooler relocation kits with no oil thermostat?
    Here is our solution.
    - Thermostat Opening Temp: 80C
    - Ports: 2x 1/8" NPT holes for oil pressure and oil temp sensors
    - 2x block adapters 3/4"-16 unf & M20x1.5 to suit popular models
    - 30mm Thick
    - Billet 6061 CNC Aluminium
    - Oil out fittings -10AN
    - Ideal for getting oil up to temp before it passes through the cooler
    - Can be used with oil filter relocation adapters
    If you want to search what thread your car has look here:
    https://www.hrpworld.com/client_imag...der/1062_1.pdf
    $175NZD incl shipping
    How it works, I will try explain it simply.
    - Oil from the engine going into the filter has 2 paths to go. 1. To the oil filter, 2. To the oil cooler.
    - The oil will not pass through the cooler back to this block when the thermostat is cold (closed), the engine will keep pressure in the oil cooler and lines when the thermostat is closed and oil will pass through the filter as normal while the oil temp increases.
    - Once the oil approaches 80C the thermostat will slowly open allowing a smooth transition where it will slowly open the other oil cooler port up to allow the cooled oil to flow back into the filter block which goes up into the oil filter.
    - The other port which oil flows through when cold will slowly get blocked off as the thermostat approaches 80C
    - So at all times there will be oil flowing to the engine.
    Now 9AGTE 410kw atw
    Aug 2006
    Default Re: Oil Filter/cooler Sandwich plate with Thermostat In-Built
    These look awesome, will they reduce the chance of dry start when the motor is cold and thermostat is closed?
    Is the oil cooler portion full flow or does it bleed of a percentage of oil to be cooled?
    What thread pitch are the sensor ports?
    Jul 2008
    Auckland
    Quote Originally Posted by aussierider View Post
    Yes they will reduce the chance of dry start up due to its design, unlike normal oil filter blocks which dont have a thermostat.
    Its full flow once the thermostat is open, as its opening it would be partial flow until 80C is fully reached. I tried to explain it above. Have a read.
    Now 9AGTE 410kw atw
    Feb 2010
    Auckland
    Niiice. Any plans to stock filter relocation adaptors as well? would make a very good combo with this
    Jul 2008
    Auckland
    Quote Originally Posted by Stolic View Post
    You can screw a relocation adapter onto this if you wanted. I dont sell relocation adapters as there are far too many on the market these days.
    Very cheap and most of them do work fine.
    Now 9AGTE 410kw atw
    Jul 2007
    If i hadnt already spent a bomb on setting up my oil system I would definitely have got this. too late for me baz
    Original Trendsetter Chief Engine Builder Harreh's Avatar
    Jul 2008
    Is there any expected complications when running these with an oil accumulator Baz?
    AW11 Turbo build
    1UZ Soarer Turbo build
    Imitation is the most sincere form of flattery
    Jul 2008
    Auckland
    Quote Originally Posted by Harreh View Post
    Nope the accumulator will still deliver oil to the filter. Even with the thermo closed. But it all depends on where you accumulator is tapped into.
    Now 9AGTE 410kw atw
    Jul 2008
    I was going to tap the accumulator into the output side of my sandwhich plate before it went into the oil cooler.
    Unless theres a better way ofcourse
    AW11 Turbo build
    Jul 2009
    What filter can be used with this?
    Also, can other fitting other then AN fittings be used?
    Oct 2009
    Stock filter I would say?
    As for fittings, yeah you could easily run o-ring flat face or whatever but whats wrong with JIC fittings?
    Jul 2008
    Auckland
    For this setup yes tapping into the side going back into the engine would work.
    You could possibly tap into the inlet of the oil cooler as well. As when the thermo is cold only the inlet port is open, the outlet port is closed.
    Now 9AGTE 410kw atw
    Jul 2008
    Auckland
    Quote Originally Posted by knightrous View Post
    Takes the OEM filters. All Toyotas are 3/4"-16 Thread.
    Yes you can install other AN fittings, the thread is a metric thread in the housing. So metric to NA adapter is required.
    Now 9AGTE 410kw atw
    Jul 2008
    Auckland
    Quote Originally Posted by dnegative View Post
    The current fittings have 0-rings on them. Personally id run aluminium crush washers.
    Now 9AGTE 410kw atw
    Jul 2009
    Quote Originally Posted by Bazda View Post
    Sorry, I should have been more specific, I was looking for which Toyota specific oil filters will work. Like the stock 4AGE filter is a Z386 filter, however I run the slightly larger Z432 from the 3SGE because it fits the 4AGE block. I tried a Z553 filter from a 3VZFE which is nearly double the volume, but the seal diameter was 2mm too big for the 4AGE block and under pressure it leaked slightly. If this is a universal sandwedge plate for Toyota motors, I assume the base is wider to support the bigger motors that run bigger filters.
    In summary, can I run a Z553 filter on this
  1. Oil filter sandwich plate
    By 1jz68u in forum Tech and Conversions
    Last Post: 27-01-2009, 08:48 PM
