Results 16 to 27 of 27
Thread: Oil Filter/cooler Sandwich plate with Thermostat In-Built
    Jul 2008
    Auckland
    Default Re: Oil Filter/cooler Sandwich plate with Thermostat In-Built
    Quote Originally Posted by knightrous View Post
    Sorry, I should have been more specific, I was looking for which Toyota specific oil filters will work. Like the stock 4AGE filter is a Z386 filter, however I run the slightly larger Z432 from the 3SGE because it fits the 4AGE block. I tried a Z553 filter from a 3VZFE which is nearly double the volume, but the seal diameter was 2mm too big for the 4AGE block and under pressure it leaked slightly. If this is a universal sandwedge plate for Toyota motors, I assume the base is wider to support the bigger motors that run bigger filters.
    In summary, can I run a Z553 filter on this
    Whats the total diameter of the Z553... The thing im concerned about is the filer housing hitting the casting of the 45 deg ports.
    Now 9AGTE 410kw atw
    Jul 2007
    If i hadnt already spent a bomb on setting up my oil system I would definitely have got this. too late for me baz
    looks like i may have spoken too soon. finally took the car for a drive with an oil temp gauge working for the first time since i did the oil cooler and it seems it works TOO well. The cold side of the radiator doesnt get up to temp fucken FOREVER!!! so it looks like I will need a thermostatic cooler after all... ffffuuuuuu
    Jul 2008
    Auckland
    Will add to your order
    Now 9AGTE 410kw atw
    Oct 2009
    You spend any more money with Bazda Vito and the guy is going to be rolling around NZ in a LFA
    Jul 2007
    Don't remind me!
    Junior Member Conversion King
    May 2010
    I finally get a worthy quote in my sig!
    Foamy's quote is awesome too though
    Jul 2008
    Auckland
    Quote Originally Posted by maj View Post
    Post edit, doesnt make sense now..
    Now 9AGTE 410kw atw
    Jul 2008
    Auckland
    Quote Originally Posted by foamy View Post
    Wish life were as easy as selling car parts..
    Fact is I daily drive a 2003 Nissan Wingroad Wagon, 1.5L of Automatic powerhouse.
    Now 9AGTE 410kw atw
    Jul 2007
    keep making awesome parts that all us 4A bretheren have wanted for years but nobody ever made and you are sure to keep getting good business.
    Jul 2008
    Auckland
    These are in stock now!
    Now 9AGTE 410kw atw
    Barry,
    how thick are these please? Also, does it need clearance around the silver lug with the two holes in it? (assuming this is the thermostat and it pops open to allow flow)
    Stu
    EP82 Starlet GT - [URL="http://www.toymods.org.au/forums/forum-members-rides/71090-stus-ep82-starlet-gt.html"[/URL] SOLD
    EP82 Starlet GT V2.0 - http://www.toymods.org.au/forums/sho...98#post1514198 SOLD
    The IS400, GXE10 with 1UZ - http://www.toymods.org.au/forums/thr...8-StuC-s-IS400
    Jul 2008
    Auckland
    Quote Originally Posted by StuC View Post
    Barry,
    Stu
    Hey, its 30mm thick and it does not need clearance, it moves internally not externally.
    Now 9AGTE 410kw atw
  1. Oil filter sandwich plate
    By 1jz68u in forum Tech and Conversions
    Last Post: 27-01-2009, 07:48 PM
