Std ecu? Does it idle up on cold start, or when turning steering or with AC on?
				 3S-GTE Idle problem
 3S-GTE Idle problem
				Hey all,
My idle on my 3S-GTE starts to drop 300 RPM from about 880RPM when I turn my headlight on and some times when I get on the brake whilst sitting at the traffic lights. Could this be a alternator and battery problem or something different?
				 Re: 3S-GTE Idle problem
				Typically, there will be some kind of electric idle-up solenoid valve, that opens when extra electrical load is applied to the engine. This will let air into the inlet manifold to raise the idle (or stop the idle from falling). Check that the valve is still functioning by removing the plug and applying 12V to the pins on the valve. The idle should go up with power on, and drop with no power.My idle on my 3S-GTE starts to drop 300 RPM from about 880RPM when I turn my headlight on and some times when I get on the brake whilst sitting at the traffic lights.
Cheers... jondee86
				Sounds like you don't have the iscv operating via the microtech, and it's hasn't got sufficient setup for cold idle up.
Has it been tuned/fitted recently?
				I got It tuned recently and the tuner said It doesnt have a cold start setup. Do you know If the ISCV can be ran through the Microtech or would I need to run wires to a switch and operate It manually somehow for cold starts?
Edit: Was Fitted before I bought the car.
				Microtech's dont have any sort of cold start or idle up afaik
				They can if you have spare inputs.
				Daily: Toyota '05 Rav4 Sport
				[weird duplicate]
				Just hook up a valve that idles motor up
Then power it when lights are on or brakes or fans or whatever makes it drop idle
Run all the inputs thru a diode for each f them so u don't get back feed
It's very crude but not as crude as the microtech hehehehehe
				I replaced the normal 3SGTE idle solenoid with a 2-wire PWM unit from a Falcon that the Microtech could control.
It worked ok'ish... but the Microcrap still couldnt handle all conditions properly. It would still stall at certain times unless i set the idle to >1000rpm (very annoying).
