Results 16 to 19 of 19
Thread: 2jzge misfire
    Default Re: 2jzge misfire
    Quote Originally Posted by dazzej257 View Post
    Has eney 1 got how they did the nsw wiring cause I think that maybe the problem I just want to check if I have done it right
    Did you read my wiki?!
    Quote Originally Posted by wilbo666 View Post
    I'd check the NSW wiring...
    http://wilbo666.pbworks.com/w/page/4...ne%20ECU%20Pin
    Wilbo's JZA80
    Wilbo's JZZ12
    Nov 2011
    hey wilbo dont u know that 99% of people on forums cant read diagrams
    they need to be spoon fed how to do it hahahahaahahha
    Mar 2012
    Yes I did wilbo and thanks for that . And dumbass if you put bat to pin 30 on they relay it keeps the starter going . You need the start signal from the t5 22 pin from the Cressida for it to work or just cut the signal wire from the 2jzge ecu and join the mc83 sta wire to it and it now works. And most people only need to be spoon feed
    Nov 2011
    Must be something wired wrong with sta and nsw if it keeps starter going
    I've done over 50 1j2j into Cressidas and never had an issue
    Anyway it's easier to cut new wire to cure rpm limit
  1. 2jzge -->2jzge+t oil feed location
    By b3n_rix in forum Tech and Conversions
    Last Post: 21-06-2012, 11:55 PM
  2. 4af misfire
    By smiley_666 in forum Tech and Conversions
    Last Post: 27-05-2010, 09:17 PM
  3. 7M-GTE misfire after ECU install
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 07-05-2010, 02:05 PM
  4. 3s-fe misfire
    By ecko in forum Tech and Conversions
    Last Post: 21-05-2007, 04:32 PM
  5. Misfire at idle. What would be the cause?
    By Tom86 in forum Tech and Conversions
    Last Post: 04-01-2007, 08:58 PM
