sounds like u have the dreaded 4000 rpm rev cut heheheheh
hay guys just finished doing my 2jzge swap in my mx83 it starts fine and idles great and drives fine if i dont push it past 3500rpm then i get a bad misfire like fuel cut . same as if i free rev it i get a misfire also at the same rpm so i just asking if eney of the other guys that have done the swap had the same prblem . or if you guys could popint me in the right direction . i have changed plugs and leads still the same it has a new fuel filter on it also . but im running the standerd fuel pump from the mx83 with constent 12v . so could this be the cause of not having the fuel pump control from the supra or not
cheers darran
I'd check the NSW wiring...
http://wilbo666.pbworks.com/w/page/4...ne%20ECU%20Pin
wilbo y do you think nsw it starts and runs fine
Mx83 has thick wires from key to inhibitor then to starter solenoid
Most other late Toyota engines have thin wires
It's means u need to hook up a relay for the inhibitor and starter to work properly
So if this isn't done right some cars have rev limit at 4000
+1 for the above. Even if the NSW pin is not the case, you'll narrow your list of possible problems
I'd be a bit anal about your saying 'bypassed' . What did you do exactly? Does NSW receive 0V?
just cut the sta and the nsw wires from the ecu
then see if it still does it
if it does then it could be anything
Opposite to dumbass, I'd put the auto in P, ground the NSW pin then try to redline engine. If it's still limited to 4000 rpm I'd start playing with crank/cam sensor. Probably check for missing teeth, continuity in harness, metal particles on sensors
i doubt its going to be the dizzy if it has a rev limit at exactly 4000 rpm
most toyotas if there is something wired wrong will have a rev limit at 2500
or at 4000
u would expect it to be missing all over the shop if it was dizzy and not spot on at 4000
did u get the ignitor all in the same kit on same motor on same front cut
as with some motors if u use the wrong ignitor u get 4000 rpm limit and error code 12 13 or 14 if its igntiion related
start signal to inhibitor
start signal rom inhibitor to relay pin 85
relay pin 86 to ground
bat to pin 30
pin 87 to starter solenoid
nsw wire goes to start signal before inhibitor
sta wir goes to start signal after inhibitor
pretty simple
