Page 7 of 17 FirstFirst ... 56789 ... LastLast
Results 91 to 105 of 252
Thread: Wakefield Park Track Day - Friday 9th of November!!
  1. #91
    loves hi RPMS Backyard Mechanic
    Default Re: Wakefield Park Track Day - Friday 9th of November!!
    earth and/or vacuum leak?
    i know previously when i had vacuum leaks it would idle high. have you tried covering the TB to see if it stalls that way?
    N/A for life...
  2. #92
    need to be able to get the thing to key start before I can sort out the idle
    There's only 4 vacuum lines on the car: Fuel pressure regulator, brake booster, oil scavenging for the head, map sensor
    Have discovered that the idle motor can have issues, so that'll be replaced.
  3. #93
    i had a crack on the underside of manifold so it was a bitch to find, could also come from a buggered intake gasket as well.
    N/A for life...
  4. #94
    Jul 2007
    still got those spacers here if you need em steve
  5. #95
    im out garthy.
    No time makes Adam something something
  6. #96
    Sorry Vito, been flat out and been under scrutiny for using my work car too much outside of work times.
    Thursday or Friday evening? Can you PM an address & I'll pop by.
  7. #97
    That wouldn't happen all of a sudden though?
    The car was working fine in the morning until about 11ish.
    I wasn't prepared to pull off the air filter. I was at a dirt track & it was very dusty. Too clogged air filter (unboxed pod type) be any kind of cause?
    The symptoms seemed to start after I accidentally tried to start the car in gear with the clutch out (because I bypassed the clutch "safety" switch). Would this have any effect?
    This is the problem with EFI, having to trouble shoot...
  8. #98
    Oct 2009
    Can of ether works well for finding vac leaks.
  9. #99
    Jumped started from the revving diesel tow car. Took some effort though as normally I don't even bother starting it or just have it idling. Excel idled fine until I disconnected the jumper leads.
    Put the battery on charge tonight.
    Doesn't help that the multimeter died also.
    Sorry if I'm cluttering up the thread.
  10. #100
    You are Steve, but that seems pretty normal for these track day threads, with tales of massive "to do" lists and the woes and hurdles that occur along the way.
    So it seems your posts are just par for the course
  11. #101
    Hey, we can't all have neat, tidy, well sorted and ready-to-go cars.
    Quote Originally Posted by wagonist View Post
    BTW Garth, that kind of means I'm now a possible maybe instead of a definite maybe...
    That doesn't change how you appear on the list.
    Edit: Also, Dneg, got the extra for friday night accom.
    Toymods Club Member
  12. #102
    Haha . I think its good that these track days seem to motivate people to both use and improve their cars! Even if it does mean a last minute dash in most cases
  13. #103
    Which reminds me, i need to order some tyres...
    Toymods Club Member
  14. #104
    Oct 2009
    And I need to find money for tyres lol
  15. #105
    Nov 2011
    Steve, you know that means your alternator is dead. Charging your battery is only a very temporary fix.
    Garth, Mitch and I will join the fun if you don't mind.
    Barring me putting it into a wall this weekend at the hill climb I should have no issues.
    You boys talking about tyres Bugger me.... I own a tyre shop and still just paid near on $2k for 4 tyres that will die if I do 4 laps at Wakefield. Soft compound yokes. It would seem that everyone is pulling out all stops for the weekend and I have been bullied into trying harder. Oh well, these tyres will sit for just hill climb/sprint events.
    I usually only need retreads to go faster than you boys at Wakefield anyway!
    ........bite here please......
    Garth, you must see me early on the day and just confiscate my car. It would seem I have had an excuse every time for the last year. Car seems bulletproof again after last outing....
  1. Wakefield Park Track Day - Friday 25th of November!!
    Last Post: 01-02-2012, 04:23 PM
  2. Wakefield Park Track Day - Friday November 12th!!
    Last Post: 18-01-2011, 08:35 PM
  3. Wakefield Park Track Day - Friday November 6th!!
    Last Post: 04-01-2010, 01:10 PM
  4. Wakefield Park Track Day - Friday 7th of November!
    Last Post: 19-11-2008, 09:11 AM
  5. Wakefield Park Track Day Friday 2nd of November!!
    Last Post: 06-02-2008, 04:22 PM
