Page 16 of 32 FirstFirst ... 6141516171826 ... LastLast
Results 226 to 240 of 470
Thread: 4A to W Series bellhousing
  1. #226
    S.A
    Default Re: 4A to W Series bellhousing
    The large 225mm GZE flywheel. The one where the clutch fits inside the flywheel to some degree.
    Its a custom Extreme ctutches pressure plate with 6 puck ceramic plate ( sprung centre)
    Hmmmmmmm thought i had a pic of it. --- ah well one of the few things i dont i guess
  2. #227
    Quote Originally Posted by 30psi 4agte
    Thanks Tiger I have a 225mm setup at home in the garage on the shelf but my Dellow bellhousing required A LOT of work (grinding) just to fit the 200mm clutch So the 225mm is no chance.
    The Niteparts bellhousing might be on my list of things to get I think
  3. #228
    Thumbs up Re: 4A to W Series bellhousing
    Pugzors & my bellhousings arrived today
    thanks to Andy's dad for dropping mine off .
    BIG thanks again to Joel for organizing the group buy for us
  4. #229
    Extreme Procrastinator Grease Monkey PuGZoR's Avatar
    Hah, my dad said you were "as happy as a dog eating hot guts" or something like that. I'm happy as hell that my bellhousing finally arrived too, just a bit annoyed that it was the 3rd day of an overseas 15 day expedition, meaning I don't get to see shiney for another 2 weeks or so. Meh.
    Thanks Joel!
  5. #230
    Just a question: What are people doing about sandwich plates and starter motors? I'm still in Malaysia, obviously, but my dad's looked at the housing and reckons that the starter motor buldge is on the opposite side, hencing making the sandwich plate incorrect too. Has my dad stuffed up, or what's the deal? For the record, I'm attempting to attach it to an AE101 4AGZE block with standard accessories, turbo manifold and RWD intake plennum.
  6. #231
    New Zealand
    Do you mean the sandwhich plate rather than flex plate? Sits between box and engine?
    Callum
  7. #232
    *edits*
    Yeah.... that's what I said.. Heh. But yeah, sandwich plate, that is what I meant.
  8. #233
    New Zealand
    My memory is fuzzy, but I believe you can use one from a suitable FWD A powered car and just add an extra cover at the bottom to fill the gap left when used in RWD. The Nite Parts ones are built to suit jap spec I believe and Aus spec mounts on the opposite side.
    Callum
  9. #234
    Ah, the bellhousing uses the standard RWD or FWD starter from almost 4AGE (unsure on 20v). The starter which you would have on your bellhousing Pugzor would be from an FWD E58 box which is at the intake side, and has a different bolt pattern to the exhaust side starters.
    I believe that the only reason that the 4AGZE has the intake side starter is that because its a bit more tricky to fit the exhaust side starter in with the FWD exhaust manifold and all the ancillaries on the exhaust side too.
    As for sandwich plates, you can either use a FWD one with the bottom inspection plate (apart from the GZE of course) or you can use a RWD one without the inspection plate.
    P.s. Jap spec or Aus spec doesnt matter, the starters are mounted on different sides due to the different boxes and ancillaries attached.
  10. #235
    New Zealand
    Hmm, my memeory is obviously failing lol Was it the clutches that were opposite sides then for the RWD's such as AE86 etc?
    Callum
  11. #236
    So basically... I need a RWD starter motor and I need to either modify the sandwich plate, or just get a RWD one? Damn FWD 'GZEs.
  12. #237
    Yeah, the clutch actuation was on the opposite side on the JDM AE86 because they had the crossflow (4AGE) engine as standard rather than the 4AC.
    I would actually reccomend you get yourself a local AE92 smallport 4age starter and sandwich plate rather than the RWD ones, the AE92 has a reduction starter wheras the RWDs were direct drive.
    Plus they are easier to find.
  13. #238
    Then if you didnt want to find a sandwich plate from another car, just make one out of flat sheet of 1-2mm steel. Thats what i did.
  14. #239
    Jun 2006
    Tasmania
    keen for bellhousing slo let me know asap please
  15. #240
    Hmm i wonder where THU187 is? Cause i have his bellhousing
  1. Imports101 MaxAction Second Series 2006
    By GeneSPIDA in forum Western Australian Events
    Last Post: 10-12-2006, 08:17 PM
  2. What torsen center is this? (10 bolt)A or G series? Pics**
    By 07XTC in forum Tech and Conversions
    Last Post: 29-12-2005, 06:14 PM
