Results 1 to 15 of 24
Thread: wiring probles with ma70
    Nov 2009
    Default wiring probles with ma70
    Hey guys i started looking into wiring up my swap aristo 2jz into ma70 89+ model.
    After extending some wires in the engine bay i noticed i had a -88 model C1 plug near my fuse box. and then when inspecting the body plugs under the glove box i found the plugs dont seem to match the pictures from supraNL guide http://www.supras.nl/index.php?optio...d=34&Itemid=50
    Nothing seems chopped or dodgy. all seems like factory wiring.
    From what ive looked at it seems i have 2 of the B2 plugs, one early and one late. Its racking my brain. Can anyone help please. Pics of my bodyplugs below.
    What looks to be early model B1 plug
    And the two plugs that seem to be early and late model B2 plugs.
    2jza70 Conversion finished, 456rwhp : 340rwkw @ 20psi
    Nov 2009
    Default Re: wiring probles with ma70
    Nov 2011
    just get a multimeter and probe where all the wires go
    print out ll the diagrams u have and sit down and go thru them once u probe them all
    its not hard just very very time consuming
    May 2007
    1st picture middle row big thick wires 1 (probably black/white stripe) starter signal from ignition barrel
    other 1 black/organge ignition power
    the aristo loom should have similar wires for the starter and ignition power for injectors/coils/ignitor
    join together and the car in theory should start... (but use the above technique to clarify what goes to what...)
    the rectangle grey plug has things like reverse lights and feeds to the dash for gauges etc...
    tacho is black/silver band
    reverse lights are red with something
    water temp gauge is a yellow with blue or green band i believe
    SPARCO|TEIN|SUPERPRO|SELBYS SWAY BARS|PERFORMANCE PARTS AND APPAREL LIKE US ON FACEBOOK!
    Nov 2011
    It's not a 5 minute job so u should at least try start doing wiring than ask for small bits of help when u get stuck
    To get someone so explain how to wire it start to finish would take weeks on here
    I could sit on phone for two days with u and tell u if u want to pay for it heheheh
    Just start probing he wires and do the easy ones
    As u slowly get thru it there is less wires so it doesn't look as bad then
    Or send us both your looms and I'll sort it for u
    Nov 2009
    Cheers for the advice guys. I'll give it a shot with the multimeter and diagrams I've got. For right now all I want to do is start it up.
    j
    May 2007
    to get it to fire it should be pretty straight forward...
    the 2 thick wires in the plug in the 1st pic are the key...
    corresponding pins should be on the orange plug in the aristo loom from memory
    Jan 2010
    You welcome to come check mine out (starts, runs, dash works) although will be slightly different cos it was a JZA70...
    May 2007
    another thing to note as i assume it is an aristo 2j with aristo loom will be needing to bridge the neutral start switch...
    Nov 2009
    I had forgotten about the neutral start. Cheers for the advice midnight. And cheers for the diagrams you sent Dave.
    Jan 2010
    The neutral start bridge is pretty basic...all of 10 mins to bridge. Given yours is manual and no cruise, simple bridge for neutral start switch will be fine
    Nov 2009
    Just thought id post up. Could never find an exact pinout for the bottom grey plug, but by using the wire colours I have the car running now and most of the gauges working. Cheers for your help guys.
    Nov 2009
    New issue. Cars been running for a while fine but just after getting off the dyno the other night i closed the glovebox and then something went wrong. The ECU wouldn't recognise the new map sensor and the thermofan and the fuel pump both stay on even after taking the keys out of the ignition.
    The thermofan is wired into the ignition off B1 plug and the fuel pump is fed off the COR.
    When i pull either the efi fuse or relay they will stop. And then putting the fuse/relay back in they wont be on.
    Ive searched around the glovebox area for a short and cleaned up all the wiring around that area but i cant find anything. Any ideas?
    Nov 2011
    u might have a bad earth due to poor wiring
    and this might be causing thermo fan to stay on which creates electricity and keeps rest of system on
    Nov 2009
    Quote Originally Posted by dumbass View Post
    I pulled the fuse for the thermofan and checked the earth. still got same problem
  1. 2jzge into ma70 wiring help please
    By iwantajza70 in forum Tech and Conversions
    Last Post: 23-02-2011, 09:47 AM
  2. MA70 wiring weirdness.
    By SlimLim in forum Tech and Conversions
    Last Post: 01-05-2010, 05:58 PM
  3. MA70 wiring
    By [email protected] in forum Tech and Conversions
    Last Post: 02-01-2007, 07:59 PM
