Results 16 to 24 of 24
Thread: wiring probles with ma70
    Aug 2009
    Default Re: wiring probles with ma70
    Tried a new relay? Its not a relay getting stuck on?
    Nov 2009
    I removed and reffitted the relays while keys were on and can hear it click on and off. but I'll try swapping another relay
    2jza70 Conversion finished, 456rwhp : 340rwkw @ 20psi
    Jan 2010
    I think what you have is a short (either a dodgy joint/insulation, or you have inadvertently wired something across these two circuits) between an EFI relay switched live feed (ie the feed that supplies power from the EFI relay) and the EFI trigger feed (the feed that turns the EFI relay on). Probably either on or near the B1 plug. This would explain why the EFI relay is activated after the key is turned off, and why pulling either the relay or fuse rectifys the issue...
    I got a job on in the morning, but happy to come lend a hand after that if you like...(and can bring a spare EFI relay, COR etc with me )
    Nov 2009
    I have found continuity between pin 1 and pin 4 on the pins that the efi relay go into. Im trying to find diagrams of where these two pins go into the cabin so i can find where the short is.
    Jan 2010
    Just two go into the cabin...
    Wires on the EFI relay are as follows:
    Black with yellow trace: 12v feed from EFI 15A fuse (all in engine bay)
    White with black trace: earth for relay trigger (also in engine bay)
    Black with orange trace: Ignition switched live for trigger (this goes into the cabin, B1 plug, and is most likely wired to M-Rel on the ECU)
    Black with red trace: 12 supply from EFI relay. This goes to COR, ECU, and others...through B1 plug.
    Nov 2009
    Turns out something internally in the PowerFC has bridged. Looks like ill have to try and find a place to repair it.
    Nov 2011
    maybe the mrel wire has issues
    u could put a relay on it instead of ecu controlling it
    u just wont have the idle motor reset eaxh time u turn car off
    Nov 2009
    Yeah i was thinking about this to just get by but ive had the tune done with the 3bar map sensor and adapter harness which isnt being read now. Would rather get it fixed than risk blowing the motor
    Nov 2009
    Just dropped it off to get fixed from a place called AFI.
  1. 2jzge into ma70 wiring help please
    By iwantajza70 in forum Tech and Conversions
    Last Post: 23-02-2011, 08:47 AM
  2. MA70 wiring weirdness.
    By SlimLim in forum Tech and Conversions
    Last Post: 01-05-2010, 04:58 PM
  3. MA70 wiring
    By [email protected] in forum Tech and Conversions
    Last Post: 02-01-2007, 06:59 PM
